Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 07-03-2008, 08:32 AM
  #6376
Rick Hohwart's Avatar
Originally Posted by K_King
Looks like the Mazda Speed 6
It is.
Rick Hohwart is offline
Old 07-03-2008, 03:50 PM
  #6377
Default Tc5
Reason why alloy blocks
I dismantle some sections of my car after almost every race meet to check bearing etc are free - when you remove the screws after a few times they come loose as some of the thread from the steering block or rear block is damaged and is attached to the screws when removed.Instead of replacing blocks thought maybe alloy is the answer.I race every week so the car does get knocked about -wish I had a sponsor to supply me some parts would solve the issue.
yeahyeah is offline
Old 07-03-2008, 03:54 PM
  #6378
K_Spec_RC's Avatar
Originally Posted by yeahyeah
Does anyone know if alloy steering blocks are available for the Tc5?
http://www.integy.com/cgi-bin/webc.c...=5722&p_catid=
K_Spec_RC is offline
Old 07-03-2008, 09:31 PM
  #6379
Powerlink's Avatar
I need some information on how think the stock carbon fiber chassis is on the TC-5 ? And how thick is the ITF carbon fiber chassis ? Thanx
Powerlink is offline
Old 07-03-2008, 10:05 PM
  #6380
BobbyS's Avatar
ITF = 2mm woven carbon fiber chassis and top plate
Stock = 2.5mm woven carbon fiber chassis and top plate
BobbyS is offline
Old 07-03-2008, 10:08 PM
  #6381
Powerlink's Avatar
Thanks for the fast info
Old 07-04-2008, 03:04 AM
  #6382
treemagnet's Avatar
Trader Rating: 17 (100%+)
Default tc5
hey everyone
just bought a tc5 n noticed that there is a crack in one of the front lower control arms so im going to replace it. wat is the quickest way to remove one? just simply unbolting the bulkhead screws to the chassis?
thanks everyone
treemagnet is offline
Old 07-04-2008, 11:01 AM
  #6383
robk's Avatar
Trader Rating: 22 (100%+)
Drop one of the hinge pin holders off of the bulkhead, and pull the arm off
robk is offline
Old 07-04-2008, 12:58 PM
  #6384
Trader Rating: 38 (100%+)
That makes sense but you can buy a lot of the steering blocks for the typical cost of aluminum ones. Plus you risk breaking more c-hubs with them. Just my thought. Looks like someone found integy was coming out with some. good luck.
or8ital is offline
Old 07-04-2008, 03:31 PM
  #6385
Default Alloy
Thanks K Spec
Now I wait for when they have some stock.
Next question:
Do you think some bearings are more suited for ashpalt than carpet?
I race outdoor so dust is a problem for the life of the bearing.
Am thinking that some brands of bearings may have a better seal to prevent dust getting in.
yeahyeah is offline
Old 07-04-2008, 05:08 PM
  #6386
IMO you would want to use a bearing that has a rubber seal for the dusty/dirty enviroment. Even though the rubber sealed bearing will have a higher "drag" on the inner and outer race. The rubber shields are easier to remove and reinstall when cleaning and re-oiling them. I have had great luck with APS Ceramics and Avid Revolutions
ercwhtsd is offline
Old 07-04-2008, 11:12 PM
  #6387
Default bearing
Any suggestion whom to try for the Aps or Avid ?
I Checked 2 sites none have the 6x10x4 wheel bearings for the TC5 listed .
yeahyeah is offline
Old 07-05-2008, 08:43 AM
  #6388
rcdougie's Avatar
Im looking to get a TC5R when they come out and I run lipo exclusively and was wondering if PPD or anyone else makes a weighted battery strap or battery posts instead of adding lead or other weights to keep a more factory looking appearance?
rcdougie is offline
Old 07-05-2008, 08:47 AM
  #6389
stiltskin's Avatar
Trader Rating: 103 (100%+)
Definitely go with the PPD tray if you are running a flat pack like the SMC. I'm not sure how well it would work with the humps on the Orion packs. They make a very nice side weight as well.
stiltskin is offline
Old 07-05-2008, 08:49 AM
  #6390
stiltskin's Avatar
I'm not positive, but I don't believe that the bearing is 4mm wide. You might want to measure one to be sure. I've had good luck with Avid bearings.
