Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 07-05-2008, 08:58 AM
  #6391
rcdougie's Avatar
Originally Posted by stiltskin
Definitely go with the PPD tray if you are running a flat pack like the SMC. I'm not sure how well it would work with the humps on the Orion packs. They make a very nice side weight as well.
Thanks... PPD has nice looking stuff but I run my lipo's in alot of vehicles so attaching weight to the battery pack is not an option for me. Maybe PPD could make a weighted battery strap and posts??? hint hint...
rcdougie is offline
Old 07-05-2008, 06:50 PM
  #6392
revo61's Avatar
Trader Rating: 18 (95%+)
There is no way to make a strap or post weigh enough.
revo61 is offline
Old 07-05-2008, 07:09 PM
  #6393
Trader Rating: 38 (100%+)
Rick posted that Associated may come out with weights that replace the posts.
If you get the diggity designs lipo holder then you dont need to attach the base plate to the lipo.
or8ital is offline
Old 07-05-2008, 07:12 PM
  #6394
rcdougie's Avatar
Thanks guys....
rcdougie is offline
Old 07-06-2008, 02:04 AM
  #6395
AdminD's Avatar
Default parts and supplier
where i know in Indonesia there is Spinx
that supposed to supply Associated parts and kits,
But untill now i could not find any of those there at Spinx
is there anyone can Help Parts and Kits for Associated Electric
in Indonesia ?
AdminD is offline
Old 07-06-2008, 03:35 AM
  #6396
Does anyone have PPD's web addy. handy? Thanks
JIMMY X5 is offline
Old 07-06-2008, 04:45 AM
  #6397
stiltskin's Avatar
Trader Rating: 103 (100%+)
Try this.
www.ppdbillet.com/RC_accessories.html
stiltskin is offline
Old 07-06-2008, 04:04 PM
  #6398
Anyone else had problems breaking their diff plates when running the composite outdrives? Ive broken 2. One while running and one while building. They break all the way through on the thin part. Seems weird that metal would break so easily.
or8ital is offline
Old 07-06-2008, 07:14 PM
  #6399
I am new to touring and in need of some help on gearing. Should you stay with the 48 pitch that is stock on the TC5 or change it to the 64 pitch? And if you should change, can you guys tell me why? Also what is a good all around starting point with each one? rubber tires on asphalt, track is tight and med bite, 45x70, no sweeepers. THANKS IN ADVANCE
JIMMY X5 is offline
Old 07-06-2008, 07:19 PM
  #6400
64 gives you more precision in gearing vs 48. 48 is more durable (for small rocks, etc that you can get running outside). For a starting point we would need to know what motor you are running.
I run 64 outside with no problems. I run a 102 tooth for a 10.5 motor.
or8ital is offline
Old 07-06-2008, 07:32 PM
  #6401
Sorry, not enough info. Maybe this will help Novak brushless 13.5 ,lipo 4800
JIMMY X5 is offline
Old 07-06-2008, 07:37 PM
  #6402
I havent had a 13.5 in my car so I dont know for sure but I would guess a 98T 64P would be a good spur to use. 13.5 would require bigger pinions vs the 10.5 so you will need the extra room a smaller spur gear would give you. Someone else could probably confirm that.
or8ital is offline
Old 07-06-2008, 07:38 PM
  #6403
Rommel's Avatar
I just shoe gooed side weight to PPD bottom plate. I then attached velcro to bottom plate and battery. Once battery strap is tightened down that battery isnt going anywhere(I use a orion 3600).
Rommel is offline
Old 07-07-2008, 04:47 AM
  #6404
Gain Time's Avatar
This gearing is for Foam tires at 60 mm. I havent take the time to figure the rollout. If you are running rubber tires you will need to go down on the pinion.
Using 48p gears start off with a 33 pin and 78 spur. This figures out to a 4.7 FDR. I ran the 48p gears and had no trouble. Again if you are running rubber tire you will use a smaller pinion due to the increased tire diameter and subsequent higher rollout.
Gain Time is offline
Old 07-07-2008, 11:04 AM
  #6405
Default set-up
new tc5 owner ' going to run bending corners outside track in the 10.5 class , would like a good base set-up . i,m talking complete no empty spots ,droop, r/h tires,gear ratio,shocks oils,springs,camber,toe,caster and body .peace.
isuzuguy is offline
