Tamiya M-08
#421
Sweet! I TQ'ed with my M08 at the most recent TCS but made some mistakes and had bad luck in the mains.
#424
Looking for a setup for high grip asphalt. My car keeps grip rolling. I haven’t tried glueing the side walls yet. Any ideas? Caster 2, camber 1(all around), gear diff 3k, hard sway bar front, soft rear, blue springs front and yellow rear, 800cst shock oil (all around), rear toe 2.6. Mid-wheel base. 5.5 ride height. Thanks
#425
800cst is very high. For asphalt you need to go much softer.
#428
Your shock oil and spring rate is way too high. You should not need to glue sidewalls on asphalt.
Start from 450 cst. Maybe 450cst rear, 400cst front. And red springs all around or yellow springs all around.
#430
What is the parts list of items needed to use M07 front end on M08? Thanks in advance.
Yes and no. The design is the same. The M07 comes with 0° C hubs and and caster is set by suspension arm mounting plate. Much better set up.
The M08 C hubs have a pull insert for 4° caster, which is an over engineered oversight, that makes them very fragile.
I swapped over to M07.
Steering uprights are the same.
#431
M07 Front uprights.. either normal or carbon reinforced
https://www.tqrcracing.com/shop/prod...asp?p_id=14818
https://www.tqrcracing.com/shop/prod...asp?p_id=12426
M07 B Parts
https://www.tqrcracing.com/shop/prod...asp?p_id=12428
M07 B Parts
#432
Can anyone recommend diff fluid for not ideal or borderline loose asphalt? My car keeps spinning out on power and I wonder if I can run the diff with only a coating of fluid without destroying the internal diff gears.
#433
BTW this is Howard from Chicago
#434
I really don't see you can go anything less then 3000 weigh......I don't think it is the diff, you might want to trim down your steering dual rate, harder the front spring (like a step) and take the steering aggressiveness from your car. M08 is RWD and you have to ease your throttle alittle bit. Unless FWD or 4WD cars throttle line movement. I drove my M08 mini for the 1st time (never own a MINI ever) and I have to drive the car like F1.
#435
Dan.....450CST is like what in AE shock oil language..? 35 or 37.5? I ran my brand new M08 for the first time outdoor on mid-high traction asphalt and it roll like a MF.....already use red rear spring and WHITE front and hard sway bar, just did not glue the side wall of the RIDE TCS tires that used for indoor carpet. But the RIDE TIRES is the tires to run outdoor. Definitely faster then M or even S grip tires. But definitely need to flue front side wall.
the car is pretty dialed. the only guy that beat me this weekend was another guy running the m-08 who had slightly harder oil, m07 front hub carriers (so he had 4 deg of caster to my 6), and sway bars (yellow front and red rear i think), and his car was a bit more stable than mine so he was able to wheel it harder. we were fully TCS legal and did not need to glue the sidewalls on med grip asphalt.
