Like Tree447Likes
Tamiya M-08
Old 12-03-2020, 06:15 PM
  #406
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by St. George
That's too bad, a body like that would be perfect for this platform.
I see one online But it is the short WB 210mm
good luck
OVA is offline
Old 12-04-2020, 09:13 AM
  #407
Raman's Avatar
Trader Rating: 94 (100%+)
There was someone on TamiyaClub that built an M06 239 wheelbase and used the Taisan 911 GT2 body, which is 236. On the rear he used arms from a TL01 I believe.
Since M08 uses different arms, that would not work.. but the arms from TC cars might
Raman is offline
Old 02-01-2021, 12:42 PM
  #408
hey guys, any Tips for a steering upgrade to convert my m08 to an drifter?
Sukram is offline
Old 03-12-2021, 03:04 PM
  #409
Raman's Avatar
Heading to track shortly.. I’m not much of a Francophile but I love this body.
kmas, kwkride and angrymelon like this.
Raman is offline
Old 03-12-2021, 03:27 PM
  #410
MD
MD's Avatar
Trader Rating: 136 (100%+)
Are the rear hubs, steering uprights and "C" hubs on the M07 and M08 the same? Thanks.
MD is offline
Old 03-12-2021, 03:32 PM
  #411
Raman's Avatar
Yes and no. The design is the same. The M07 comes with 0° C hubs and and caster is set by suspension arm mounting plate. Much better set up.
The M08 C hubs have a pull insert for 4° caster, which is an over engineered oversight, that makes them very fragile.
I swapped over to M07.
Steering uprights are the same.
Raman is offline
Old 03-12-2021, 03:35 PM
  #412
MD
MD's Avatar
Thanks for the quick answer. I assume the rear hubs are the same.
MD is offline
Old 03-12-2021, 03:41 PM
  #413
Raman's Avatar
yes
Raman is offline
Old 03-12-2021, 03:44 PM
  #414
MD
MD's Avatar
yes
Thanks again. I bought an M08 and he has parts from an an M07 in the same parts box. Is there an easy way to tell the difference between the M08 "C" hubs and the M07's?
MD is offline
Old 03-12-2021, 03:47 PM
  #415
Dan
Dan's Avatar
Trader Rating: 76 (100%+)
M08 has an insert on the lower hinge hole. M07 c hubs do not and are much stronger too.
Dan is offline
  #416
Raman's Avatar
Yes, M07 doesn’t have the highlight piece. The hole is smaller just for suspension pin
Raman is offline
Old 03-12-2021, 04:41 PM
  #417
MD
MD's Avatar
Thank you for going to all that trouble. I really appreciate it. Stay well.
Raman likes this.
MD is offline
Old 03-13-2021, 08:10 AM
  #418
Raman's Avatar
Did some practice laps with Alpine A110 body with S grips at track. It was first time for me running 210 wb on RWD, as well as Alpine body, on a track layout.
Overall, quite impressed. Great steering, very neutral body. Majority run the Suzuki, Yaris.. maybe those work better for FWD?
Going back today, will try the Ride 33.. there’s no M chassis class for us presently, so I plan on running in VTA class just go get some track time..
Raman is offline
Old 03-15-2021, 02:51 PM
  #419
Raman's Avatar
For Saturday, I hopped in to VTA race with my M08, so I could get some laps down and work in the ride 33. No major change in set up yet until the centre nub in tyre is gone. Last main finally broke into low 19s. I was on pace with VTA on in field but on back straight I could not keep up, due to 24t gearing and reedy 21.5 FT. On the final lap, I finally passed one of the VTA drivers 😉
OVA, kwkride and angrymelon like this.
Raman is offline
Old 04-19-2021, 08:10 AM
  #420
Raman's Avatar
Guess who took 1st place at TCS in his yellow Alpine A110 M08 😉
Dan, kwkride and angrymelon like this.
Raman is offline
