Originally Posted by Zerodefect
(Post 15535729)
CRC tires, way softer front springs, Xray gear dff with 40,000wt Kyosho diff fluid, some width adjustment shims front and rear, and that car should be pretty dialed.
1mm droop front and rear, 1-1.5 camber, stock caster. |
F1 is no different then touring cars when it comes to set ups. What works for one may not work for another.
The crc tires are probably the best for the black rug. Montech wings seem to be the most durable. personally I run a very stiff front end(keeps the wing off the rug) and a very soft rear pod and diff(2.3 spring, 10k in the tubes and 8k diff). I run zero front droop and about 1.2-1.5mm pod droop. Enjoy trying set up changes and let us know what you end up with. |
Since we are talking about setups, what are you using for setup stations? I have a touring car setup station, but it doesn't fit on the axle of the F1.
Originally Posted by Adlattire
(Post 15535800)
https://www.hudy.net/xhudy/products/proddesc.php?prod_id=736&kategoria=64&Hudy_Session =61ec81f74c4a94d423b88b1544a11ab5 |
Originally Posted by Khador12
(Post 15535813)
I use these with my TC setup station.
https://www.hudy.net/xhudy/products/...b88b1544a11ab5 |
(Post 15535817)
Do these go over the axle to give the setup station something to tighten up against?
(Post 15535661)
I'm new to racing F1 and I'm trying to get things together. My first concern what tires I should run. I have an Xray X1 '17 and race on CRC black carpet.
they are allways right ! carpet red rear med-soft green front I have it on my SF4 on black carpet and they are awesome ! |
Originally Posted by Quinny45
(Post 15536083)
If you want the best pre-mont tire on the market go with volante !
CRC F1 tires on asphalt
Anyone tried the CRC F1 tires on asphalt? Thoughts please. |
Originally Posted by Ted Su(TW)
(Post 15536339)
If the front end of the car is bouncy at the end of the straight, what change needs to be made?
Originally Posted by trilerian
(Post 15544923)
Originally Posted by chensleyrc1
(Post 15545085)
Try some tube grease\silicone on the kingpins.
Lube is not the issue. I think the front springs may have been too soft causing the wing to bounce off the carpet. Anyway, I run 15k kyosho and 30k kyosho on the king pins.
sorry, thought it’s pan car |
