Team Associated B6 & B6D thread
#106
Thanks! I'll just mod the B5 spindles like they did on the world's car and swap rear hubs then.
#107
spencer rivkin's B6 @ EOS
http://eos.redrc.net/2016/04/chassis...pencer-rivkin/
looks like he has an alloy steering kit in there already
and also a brass pivot on the front end
#108
Anyway to answer your question, I wouldn't get the B6 unless you were exclusively running on astro or carpet. So get the B6D.
#109
#111
Pre ordered the B6D. Looks like the geometry stays very close to the B5m so I doubt it handles much differently or will be markably faster. Looks like a good well refined buggy. Hopefully the kit comes with ti-nitrade shock shafts and ti turnbuckles like the marketing pics. Also like that it comes with more Aluminum and good bearings. Justifies the extra $30.
AE managed to address some of the weak points of the b5 i.e. the front spindle inserts. Im going to get the parts to run the laydown tranny just to see how it works on dirt. I race on medium grip indoor so it may not work but I like tinkering.
#112
Started updating the first page, breaking up some of the categories to make it easier to find things and easier for me to edit later.
BTW, here's the first B6 hopup:
For those who like to build shelf queens
#113
For the Xray crowd.
#115
#116
Thanks man! I think the new layout for the first page will make things easier to see and read.
Which reminds me...when you guys get your hands on the new kits, please let me know which hopups will crossover. I have a feeling that parts like the Avid/Schelle shock bushings (as an example) will fit the new car, but I will need someone to test it so I can update the first page.
#117
I guess my point is, the B6 is much more of change compared to the B5M platform, then the B6D is to the B5M.
Seems like you if you drive primarily on Clay (Much of the SoCal circuit), which do you choose? Their little chart has Clay in the middle and shows them both "good" for clay...
From the sounds of the interviews ive seen about it the b6 will work on any clay just the b6d would be easier to setup and drive
#118
I'd actually be surprised if the fundamental geometry was changed. The arm lengths and shock mounting locations on the arms are the same on the B3, B4, B5, and B44 cars. I'd be shocked if these were changed. The adjustable height hubs front and rear would make a difference and I suspect the top hole results in the same geometry as the other cars. The bottom hole would allow for a lower ride height without the roll center compromise that just running the standard geometry lowered would have. Everything could be different of course but if this is based off of a modified world's B5, I'd doubt it
#119
Trader Rating: 89 (100%+)
ETA
Tower has a pre-order up saying late June , 30$ coupon will bring it down to $279 and they don't charge your card until it arrives.
