Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 08-18-2016, 07:06 PM
  #2701
Trader Rating: 21 (100%+)
Originally Posted by celt
Nope, my understanding, he ran it that way at the Nats.
He won the Hot Rod Shootout with the inverted shock setup too.
MX304 is offline
Old 08-18-2016, 08:01 PM
  #2702
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
i've got to imagine that whatever ty's deal is with HB, it's ending soon. it'll be awesome to see what he can do with a legit manufacturer. AE gonna open their wallets big time (hopefully).
RC*PHREAK is offline
Old 08-18-2016, 08:33 PM
  #2703
[YOUTUBE]https://youtu.be/4aiKFdN4dZQ[YOUTUBE]
Those zany Tessman are quite cleaver
Originally Posted by xyzracer
The problem with mounting the shocks like this is that the pistons are sitting in the air gap at the top of the stroke so you have no actual damping at full droop
mgers75 is offline
Old 08-18-2016, 10:29 PM
  #2704
xyzracer's Avatar
No kidding....sounds like they figured it out!
xyzracer is offline
Old 08-19-2016, 01:31 AM
  #2705
Re. Leaky gear diffs...I had same issue when we first started using them in B5m. Try blue hylomar, it's a full size auto gasket sealant. You only need a tiny/thin amount, I apply it using a watchmakers screwdriver. Can either apply it to both sides with gasket inbetween, or ditch the gasket. My 5 gear diff never leaked afterwards, and built my 6 the same way. Use a toothbrush and motor cleaner to remove any excess after you've screwed it down tight.
andrewcoley is offline
Old 08-19-2016, 04:13 AM
  #2706
celt's Avatar
Originally Posted by HeavyD99
Can anyone running a B6 gear diff comment on its ability to hold oil? I had one in my SC10 and within a few race days all the black grease would have worked its way out. I had one in my B5 and it leaked. I bought the aluminum cap and it was better, but still not great.
Have a gear diff in my B6 carpet car. Not an issue so far, none, perfectly dry. Built with 5K as I recall.
celt is offline
Old 08-19-2016, 07:24 AM
  #2707
Mason's Avatar
have had bladders in my parts bag for awhile. just never got the motivation to go forward with it!
Mason is offline
Old 08-19-2016, 07:40 AM
  #2708
Strange people have played around with running the shocks upside down since the late 80's. It's nothing new. It does change a few things but for the most part the added unsprung weight isn't worth it.
Fred_B is offline
Old 08-19-2016, 07:58 AM
  #2709
Suspended
Trader Rating: 61 (100%+)
That car shares very little with a D216 out of the box. I'll be concerned when Rivkin or Cav do it.
Socket is offline
Old 08-19-2016, 09:38 AM
  #2710
I don't know about the upside down shocks idea, but I really like the way they build their shocks. It looks like they are completely dead and removing the bleeder will allow the pressure somewhere to when the shaft is compressed or weather changes. Wouldn't this lead to no air being sucked into the shock which means less maintenance?
When I first saw that vid, I looked for a part number for bladders but apparently AE doesn't make them? I was going to get some HB or TLR bladders to see if the would fit but totally forget about it.
mgers75 is offline
Old 08-19-2016, 09:54 AM
  #2711
Tessman isn't there for the 2wd program, he's there for one of the best 8th scale teams and the killer d413
rcbuggies is offline
Old 08-19-2016, 10:41 AM
  #2712
Who is that Guy's Avatar
Mine has been pretty good. One thing that helps is double up the paper gasket....also put a thin layer of black grease on the gasket and the diff. Once you have it assembled take more black grease and coat the area where the screws are to help seal it up on the outside....works very good !!
Who is that Guy is offline
Old 08-19-2016, 11:41 AM
  #2713
suby723's Avatar
The front and rear sway bars are available now on ae's website. Just ordered both.
suby723 is offline
Old 08-19-2016, 04:08 PM
  #2714
onefast8's Avatar
Trader Rating: 41 (100%+)
For anyone late to the party (like me) Tower has their eCash deal going again.
Started yesterday and ends the 24th
Update: Ideally you should join the SuperSavers Club through Tower a couple days before you buy your stuff and usually they sent you slightly better coupon codes to use toward your purchase. So you would buy a membership. Wait for eCash promo date. Place your order with you new member discount codes then get the eCash promo to use on upgrades in a few weeks.
http://www.towerhobbies.com/tow_ecash.html
http://www.towerhobbies.com/coupon_codes.html
Edit:Update
onefast8 is offline
Old 08-19-2016, 07:38 PM
  #2715
Damn, I just put a 450$ order in on with towerhobbies.com on the 16th...
microjam is offline
