Team Associated B6 & B6D thread
#245
Here is the short list:
Q: Do the Dirt and Carpet cars have the same chassis?
A: Yes
Q: Which car does Kody plan to run at OCRC?
A: B6D with the optional parts to make it a laydown for tuning. Most cost effective
Q: What are the turnbuckles made out of?
A: Steel with a nickle finish
Q: Which shock shafts are in the shock?
A: V2 shafts. AE now has molded V2 pistons.
Q: Which rear shock bodies are on the car?
A: 27.5mm
Q: Which parts are the same as the B5M?
A: Diff, not the outdrives. Current outdrives "should" work but need shimming. Front shocks. Ball studs. Maybe more small things.
Q: Will the b5m body fit?
A: Poorly.
Q: Cant the shock be mounted on the front are the rear tower on the Dirt configuration?
A: No
Q: Will the +4mm rear C mount work?
A: No, the inserts and C/D are new. The C/D can use the same inserts now to achieve many tuning options. Without changing the C mount.
Q: When will the B7 be out?
A: In the future.
Q: Will ae be making conversion kits for go back and forth between configurations?
A: Not at this time.
Q: Eta on the manual
A: Closer to shipping dates.
Q: Is the front bulkhead/hinge brace new?
A: yes. cant be used on B6.
Q: Will there be an RTR B6 any time soon?
A: No
Q: Why make a B6 2wd before the new 4wd Car?
A: 2wd cars are able to be designed faster.
Q: T6D coming?
A: One project at a time.
Q: When will the B6 Factory Team be out?
A: HAHAHAHAHAHAHAHAHAHAHAHAHA (my response)
A: Kody's Reponse "this kit is already very well equipped"
Q: Can the B5M FT front axle and hex be used on the b6?
A: No, the front axle and hex are different. The rear axle/CVA is the same.
A: Yes
A: 27.5mm
A: Poorly.
A: No
A: In the future.
A: No
Q: T6D coming?
#250
You can see the grub screws pretty good here. I kinda have to agree though that they could have used some shielding. But I guess we'll see if it's an issue.
#255
