TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread
#9016
#9017
Frank Root how much shorter is the team chassis that everyone is running? And i was not trying to be a a#$ about the 3.0, i just had the feeling with all the changes being made to the 2.0 that a new buggy would be out by this time next year. Also what are you guy gaining going from 4hole piston to the 2holes? just make it in simple terms front vs rear if it gives more steering less steering more traction less, i would assume its more responsive but has less rear bite.
#9019
New to racing buggy and have been looking at posted setups for the 22 2.0. I see positive toe (+) listed and want to be sure that is referring to "Toe Out"??? If so, are the listed numbers total toe out or is it toe per side?
Also, I have always know Left and Right to be from the back of the car. This is the case correct? The reason I ask is because I have a set of aluminum hubs and the ball mounts are offset and want to be sure that the offset is correct.
Thanks in advance
Thanks in advance
#9020
Thanks in advance
Thanks in advance
And if you were a wee little guy sitting in the car like you were driving it, looking forward towards the front, the left is left and the right is right. So again, yes.
#9023
Doesn't positive toe produce the wheels to constantly generate force against one another making it more stable on straights...kinda like an F1 car?
#9025
Anyone tried the B5 offset cups w/ AE studs on the new cranks? The SCT 22 cups seem to be MIA here locally. I will need to order some and doubtful, I will have them by the weekend. The tie rods are getting into the springs pretty good without the offset cup in place. I have the AE cups and studs, just thought I would ask before I start modding after work.
#9026
#9029
Thanks!
