TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 11-25-2014, 05:40 PM
  #9766
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
Originally Posted by XXXDad
except 3X1.3
Ultraspeed84 is offline
Old 11-25-2014, 09:57 PM
  #9767
LosiRacer33's Avatar
So why are people moving to a shorty over the saddles and then adding weight to the side of the shorty? The saddle packs are about 90grams heavier. Is that too much weight?
LosiRacer33 is offline
Old 11-26-2014, 03:27 AM
  #9768
Thats a good question, I was wondering the same thing after seeing Cody H's recently posted setup.
nitro-rob is offline
Old 11-26-2014, 03:43 AM
  #9769
Default after market water fall brace
Who is making the water fall brace that let's the shorty pack fit inside and touches the motor. It has a big hole cut out for a fan to sit on it.
S.TRIPP77 is offline
Old 11-26-2014, 03:48 AM
  #9770
Originally Posted by mo
Yes. You can order them 3D printed from my Shapeways store, https://www.shapeways.com/shops/MPP.
I just made a small tweak to it to give more clearance to the motor tabs. I also added a stock replacement waterfall with a fan mount.
Hello mo I want 3 of the braces that will let the lipo sit farther back. Pm me what u need
Old 11-26-2014, 04:05 AM
  #9771
Roger H's Avatar
Trader Rating: 24 (100%+)
For me it wasn't so much the added weight.
With the shorty pack we are able to add the weight where we need it, keeping the majority of the weight in the center line.
Roger H is offline
Old 11-26-2014, 06:09 AM
  #9772
That's what I thiught. But then I saw that guys are adding 20grams on each side, basically outside of the centerline. The only thing I can imagine is that the weight can be more concentrated to the front or rear.
Old 11-26-2014, 06:29 AM
  #9773
Roger H's Avatar
That is correct. With saddles you have almost too much weight, and it's spead out in the wrong places.
You also have a different chassis flex charactistic with a shorty vs. saddles
Roger H is offline
Old 11-26-2014, 07:19 AM
  #9774
mo
mo's Avatar
http://www.shapeways.com/shops/MPP
Just go to the site and order. That's it. They are printed to order.
mo is offline
Old 11-26-2014, 09:11 AM
  #9775
hoyt1967's Avatar
Trader Rating: 36 (100%+)
What are most of you running for trailing spindles for MM? I want some aluminum ones and see them offered in 4 (tlr1075) and a 2 (tlr1073). For the price I want to get the right ones, the stock plastic ones have worked well, just have broken too many.
hoyt1967 is offline
Old 11-26-2014, 09:14 AM
  #9776
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Originally Posted by racer888
Tried searching can't find my answer so sorry if it's been beat to death but... I'm looking to replace my 17.5 motor with a new one and looking for some insight in what people are running 17.5 only and what kind of gearing/end bell timing
Thanks in advance.
I don't run stock a ton, but when I have, I run a Schuur Speed V3, 38-42* of timing, and geared 29/69. It ran great at Surf City and I was able to come home 2nd out of 110 with the top 3 all running Schuur Speed V3's.
Originally Posted by vr6cj
anywhere to order the TLR331014 -2.5 chassis besides Feebay? (Hate Feebay with a passion)
Call Pacific Coast Hobbies, they have them. 310-530-7127. They'll take a phone order and ship it out, probably today.
Frank Root is offline
Old 11-26-2014, 09:23 AM
  #9777
racer x 1's Avatar
Trader Rating: 27 (100%+)
Hey frank what shock set up are you running in mid motor at ocrc? Is maifields 3x1.3 and 3x1.4 what i should be starting with?
racer x 1 is offline
Old 11-26-2014, 09:28 AM
  #9778
After alot of research I ended up getting a d4 with HT rotor ..thanks for responding though
racer888 is offline
Old 11-26-2014, 09:47 AM
  #9779
Bivens's Avatar
Maybe someone else will correct me....but I don't believe those are 2.0 spindles....I think the offset from kingpin to Hex is more on those....1.0 geometry...
Bivens is offline
Old 11-26-2014, 12:33 PM
  #9780
hoyt1967's Avatar
Well I guess then I should ask, is there an aluminum spindle made for the 2.0??
hoyt1967 is offline
