TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread >
Like Tree1Likes
Old 10-15-2014, 06:17 PM
  #9031
Trader Rating: 27 (100%+)
We do use the spindles in bell crank kit for the buggy right? Because if you look at manual for 2.0 SC it calls for a spacer between the bearings and they aren't in the kit.
RandyJones is offline
Old 10-15-2014, 06:21 PM
  #9032
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
hmm, interesting.
Wildcat1971 is offline
Old 10-15-2014, 07:05 PM
  #9033
Jerm13's Avatar
Trader Rating: 36 (100%+)
Yeah, I think it was Frank in the 22T thread said they were only for use in the SC. Hobby shop is holding mine. Ill have them Saturday but wont put them on as I am going to run MM for the first time. Don't want to try to many new things all at once.
Jerm13 is offline
Old 10-15-2014, 07:19 PM
  #9034
Errokk's Avatar
I would! Just saying.
Love the Bellcrank in mine which is a 1.0 with 2.0 upgrades, bug handles better then ever!
Errokk is offline
Old 10-15-2014, 08:30 PM
  #9035
JP.R's Avatar
Yes the spindles that come with the bell cranks are the correct ones for the 22SCT 2.0 and the 22 2.0 buggy.
The SC manual calles for the crush tube in between the bearings because the SCT uses a different axle/hex than the 22 buggy.
JP.R is offline
Old 10-15-2014, 11:01 PM
  #9036
JP I have been running the low grip set up you posted a while back. I really like the way the car handles, very easy to drive. Our track is indoor clay,sand mix. Not really low grip, but hard to get ahold of. Kinda slick. The car works great, but I need more steering entering the corner, and mid corner. What can you reccomend?
Dale.0 is offline
Old 10-16-2014, 04:20 AM
  #9037
That's what I was kinda thinking Jp after I thought about it for a while. Thanks for info though!! Got the front end all done on Tyler's 22 2.0 and its soooo smooth now. My EPA came out exact same L-R too!!
Old 10-16-2014, 04:53 AM
  #9038
JP.R's Avatar
Glad the setup is working well for!
If you have the bell cranks I would try going to the low mount ball stud on the rack. If you don't have the bell cranks yet, try going to 1.5mm on the inner camber link.
JP
JP.R is offline
Old 10-16-2014, 06:52 AM
  #9039
JP, I do have the bell cranks, and am using low mount ball studs.
Dale.0 is offline
Old 10-16-2014, 07:04 AM
  #9040
JP.R's Avatar
Maybe try going down half weight in shock oil or go to 1.5 under the front inner ball stud.
JP.R is offline
Old 10-16-2014, 07:13 AM
  #9041
Ok I will give that a try. Go down half weight both front and rear?
Dale.0 is offline
Old 10-16-2014, 07:41 AM
  #9042
JP.R's Avatar
I would do just the front
JP.R is offline
Old 10-16-2014, 08:40 AM
  #9043
Thanks JP. I will give it a try.
Dale.0 is offline
Old 10-17-2014, 05:12 AM
  #9044
skeasor's Avatar
Originally Posted by Wildcat1971
The B5 cups have a kinked/angled cup. For the same reason as TLR, to help the link clear the springs. I will try it tonight.
Did you try this the other night? How'd it work out?
skeasor is offline
Old 10-17-2014, 06:16 AM
  #9045
works fine.
Attached Thumbnails TLR 22 2.0 Race Kit: 1/10 2WD Buggy thread-20141017_061017.jpg
