Hot Bodies D413 1/10 4WD Buggy
wire clips are nice
Not sure on the Proline body, but at least on the Jconcepts one you want the motor wires to run towards the side so they don't hit the body.
Just sent an email to exotek about a split diff mount and saw this afterwards negating my question lol:
D413 4-PIECE SPLIT MOTOR PLATE SET - Exotek Racing
Nice ! So you can use it on the stock chassis right ?
Tech Legend
if I am viewing the right setup:
Hot Bodies D4'13 - Ty Tessmann - Chitown Shootout - Leisure Hours - March 2016
Looks like he ran a prototype slipper. not sure how a slipper correlates to diff oil exactly, however the impression I have been given is that you run the diff pretty heavy if you don't have a slipper option.
Your diff settings of 10-50-5K I would probably change to something like:
10-200-10 to start, or even heavier in the center like 300-500k with the same front and rear diffs.
Are there any upgrades on your vehicle? (different chassis in particular?)
Looks like it. Looks like a lot of excitement about this at the track i go to as well, lots of HB413s around there.
10 50 5 what I run and its great. Sounds like you need the rear to rotate for the 180 turns. I did not look up the set up sheet your using but try lowering rear camber link with 1mm spacer on inner side/tower. Will get the rear to rotate for 180 turns.
Suspended
D413 clay setup
Hi guys i just bought a d413 and yet to run it. But im looking for setups for high bite med size clay with id say large jumps atleast for indoor.thinking about ty's reedy setup track has a big triple so im prob gonna buy vrp 1.6 or 1.7 2hole or maybe both any suggestions and advice would be appreciated
Split center diff clamp
Where do you get the split center diff carrier for the d413?
Tech Legend
This will be stocked by Amain and is made by exotek. not sure how soon, maybe a week. You can also order it direct from exotek.
On-power steering entering a corner is tricky, as all the weight is in the rear of the car leaving little to let the front tires grab. Braking just enough to get you 75% thru the corner without pushing or needing apply more throttle is probably the best. The car needs to be in a neutral stance or even slightly nose heavy to navigate a tight corner quickly.
Last edited by DWheels; 03-15-2017 at 10:48 AM. Reason: My rough track description is subjective and vague :D
The stock 4 hole 1.3 pistons made to 3 hole with glueing one hole has worked fine for me indoors with B5M Purple/Yellow springs with 37w/35w jumps good could go heavyer oil up Front . Now the track i raced at has welded metal jumps so not much downside landing to them and more limp to the face of them .
21mm all around ride height and cut down on the droop with the shock rod ends to almost to the first line on them . 1mm washer underneath the Front camber link on the carrier blocks (smoothes the steering) . Long camber link on the Rear end and Front end link shorter .
10,10,000, 10k diff oils .
Note when the clay drys out you might want 7k in the rear for more grip/rotation . Had the hardest time getting side bite out of corners would actually spin out and not enough rotation on power exit with the 10k in the Rear diff i think that was the cause.
Wetter clay no problem at all buggy felt good.
Tech Legend
have you tried 3 x 1.4 at all DWheels? if so, what conditions you feel to use it?
Anyone know of a place or a part # for more shims in either black or orange?
When picking my suspension setup I like to use the following to help me:
Springs = The level of traction the track has to offer. Stiffer springs for higher traction tracks.
Oil = Mostly based on ambient temperatures. Colder temps the lower the weight/cst; the higher the temps the higher the weight/cst.
Piston = How rough the track is and what amount of pack I am looking to achieve. Fewer and smaller holes provide a high amount of pack and for smooth tracks. Larger and many holes provide a smoother feel and for rough tracks.
Heres the indoor track i race at did not care for this layout that weekend though tough time getting Rear traction on power exit of the corners that day dry slick clay practice was moist.
https://youtu.be/tdAYTDiCcpQ
2017 4wd Buggy A Main Elite at Bumps and Jumps RC Speedway
Tech Legend
I think I jumped in at 3x1.3 all the way around when I first built a D413. I would try out 4x1.3 would be at a weathered blown out track. Where you are looking to soak up as much bumps and inconsistencies as possible.
the piston combo does feel great, 3 x 1.3 all around. just more consistent feel than the 2 x 1.6 and 2 x 1.7 all around.
Suspended
D413
Thanks everyone for the input yea im bout to order either 1.6 or 1.7 2 hole vrp piston been hearing alot of great thing with them on d413...again thanks for the advice cant wait to get d413 on the track
