Hot Bodies D413 1/10 4WD Buggy
Stock positions on the Front end except the camber link is in the inside hole from stock outside hole on the bulkhead Ackermann is stock I'm pretty sure and some toe out on the front .
The rear camber link also effects how the car steers. Maybe try going to the 3 hole on the hub?
Slapping a set of D413 a arms on a vintage wheeler thus I can't remember the size of the flat head screws used to secure the stock a arm stiffener plates. Will be using CA as well.
Than you
Than you
Looking for setup help
Looking for a good 13.5 setup
I got the schelle chassis and stock pistons and I believe stock springs.
Any help would be appreciated
Thank you.
Running on high bite clay and medium to high bite as well.
Thank you.
Tech Legend
one thing I noticed about the current Ronnefalk setup for carpet and the setup sheet is the sheet is measuring the entire shock length, but his numbers are using the old sheet method of shock length.
Is there an advantage one way over the other?
Man I hope exotek or someone can look into making a split center diff. would be killer.
Tech Legend
Anyway, so what are some impressions on running the vehicles with the motor up front but still a shorty pack and electronics in the back? How well does it balance, etc and what conditions is this beneficial and why?
I think it may depend on the ESC in question as well as the location you put the ESC.
Speaking of which, what are peoples recent thoughts on running the ESC behind the motor with some of the newer chassis designs like the exotek? I did this on my Rango and liked the feel and balance with the shorty battery.
Tech Legend
Looks like tomorrow is the day to get the buggy out there. Looking forward to seeing what is what with it.
Im out of town and needing the LONG screws M3X20mm for bulkheads
Did anybody try titanium screws OR find an alternative?
thanks
thanks
Got to try the 413 out last night love the way it turns but not having luck with the jumps wants to jump nose heavy have the shorty on the right side along with transponder have speed control on left front receiver in back behind motor didn't get through 3 packs of practice and landed nose heavy on right front and broke steering arm and caster block at the same time any ideas this may just be too much for this old guy.
