Hot Bodies D413 1/10 4WD Buggy
Tech Legend
yeah here part of the carpet is over some really uneven surface that can get bumpy. I found I was getting kicked around more than I liked the feel of the 3 hole pistons instead.
I got some extra suspension blocks for the D413 and i want to reduce the Anti squat to reduce to much pitching when i brake with the stock chassis on lower grip outdoor . So the 2 dots or 1 dot are what degree ?
http://site.petitrc.com/setup/hotbod...413_Charts.pdf is a great break down of the different pills, springs, sway bars and even FDRs
Now that's good information.thanks.
Im going to change one of my cars over to stock 13.5. What gears are we using 68/28? I know depends on track but range of pinion you guys are using please. Most likely OCRC
Will these work as a replacement pin for the wheel hexes? Size looks good to me.
https://www.amainhobbies.com/schumac...hu4390/p268086
Tech Legend
Looking at the setup sheets, I noticed that some have different antisquat settings for the exact same block configurations? Anyone else notice this?
It appears that the antisquat settings got adjusted by about +1.5° and also displayed new options, that were not shown before.
Also Rear Toe-In changed as well. Those settings are something I struggled to understand for a while but now have a better understanding. When spacing your anti-squat pills out from the diff case the relationship between the F/R and the R/R determine the amount of rear toe in. And your wheel base.
For instance if you run 1mm spacer in the F/R and 2mm spacer in the R/R, there is a 1 mm difference in your spacing. This gives you the .5mm / 1.5mm, thus 2.0° Rear Toe In.
Tech Legend
yeah it was something odd. The spacers make sense though and I don't mind the setup at all. If they can get diff access setup better the vehicle is quite nice.
One thing I did find of interest when pricing the MIP puck setup for the D413 was it was mentioned that certain spacing combos don't work with the pucks. And its combos I am seeing being ran on some of the latest setup sheets. Anyone else see this?
Tech Legend
What I mean is that if its not a problem with the stock drives, did they not make the pucks similar in length to the stock drives is what I am getting at.
Well I could reduce the anti squat to 1 degree to reduce the pitching when I'm on brake but im realizing, from running indoor when I went with stiffer springs up Front and Rear i reduced it a lot .
I'm going to try the red spring up Front outdoor first or the B5M spring .
I just picked one up. What's some important things to build into this kit? What's a good set up for med bite clay with small to medium jumps? I'll start researching but appreciate any advice here.
Tia.
Tia.
