Hot Bodies D413 1/10 4WD Buggy
How is your experience with running the motor in front with shorty?
I have schelle +4 alu and muchmore combo so i hope that there should be enough room.
Interested in trying that setup 😊
Ive run mine this way since I got it (running indoors on carpet or AstroTurf). I'm using Orion electronics and had the clearance issues with the steering with the standard chassis, so got the HB +6mm carbon chassis. Im also using some hand made roll bars, 1.8 front and 1.5 rear and the car is very stable in both pitching and rolling.
I haven't gone through this thread but I was wondering how this buggy stacks up against the 22-4? I owe the 22-4 and really like the way it handles. But, I am over the constant diff ball changes with this buggy as it isn't the easiest to always change them. Just wanted to see your guys thoughts about the two buggies. Also, does anyone know of a possibly new HB 4wd buggy? thanks!
Just got this buggy built and I noticed something that struck me odd. The center drive shafts move a ton, like 4-5 mm back and forth between the center and front/rear diffs. Should I put an o-ring or something in the diff cup to take up this slack?
That's just the way they are. It won't affect anything.
I've driven the 22-4 and have the D413. The only way I can describe what I've experienced is the Losi seems very smooth, almost sluggish. The 413 on the other hand seems edgy, like it's always on the verge of out of control. But for me, the more you push it, the better it gets. But, everybody has a different driving style, you'll probably get different opinions
I run the 22-4 mostly because it is plush, works well and seems to allow you to get you of shape and save it a bit easier than the HB. I have not had diff issues in 13.5 but the 22-4 was just plain bad for me in open mod where it would eat belts and bark diffs easily. The HB could run a 2.5t and not have any issues with the drivetrain!! I will usually practice with the HB when I get the chance and it normally goes as fast or slightly faster than my Losi but not as consistent or easily over a race length.
Ive been looking for 1.8 and 2.0 roll bars but havent found any info yet.
Any tips where i can buy the correct steel online?
1.8 would be .059
2.0 would be .078
Careful with the 2mm roll bar, as I don't think you can use the standard ball ends, the wire won't fit inside the ball.
