Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 06-26-2014, 01:08 PM
  #3346
kdeleon's Avatar
Originally Posted by Rybeau40
Took this from an old post obviously, but what type of 3X1.3 pistons are you running? (Brand wise) I have no more spares for drilling and want to put in 3X1.4, but need a reference to what will work in these shocks.
TIA!
I think the folks that are running 3 hole pistons are using the HB ones. I think one person drilled the blanks. Another put in a small screw. And I cut down a tooth pick and glued it in (recommendation from Torrance). Since the kit included 4 x 1.3s you can just block one of the holes. I thought that I would give it a try as I had already used my blank pistons.
kdeleon is offline
Old 06-26-2014, 01:30 PM
  #3347
Trader Rating: 39 (100%+)
Have any of the guys with gear issues considered having some made through a place such as http://www.rushgears.com/ ? They have a variety of materials and can make the gear to whatever dimensions. I'm thinking of using them for a project I'm working on.
ufoDziner is offline
Old 06-26-2014, 02:16 PM
  #3348
Matt :-)'s Avatar
Mr Deguzman, do you know any info about the next couple shipments of D413 kits and/or spare parts scheduled for the U.S. ?
Matt :-) is offline
Old 06-26-2014, 02:26 PM
  #3349
Rybeau40's Avatar
Originally Posted by skyline1015
I am using the AE SC10 shocks
How are they working for you vs. the old shocks? What mods did you need to do to get them to fit.
Tia.
Rybeau40 is offline
Old 06-26-2014, 02:58 PM
  #3350
boudin4evr's Avatar
Trader Rating: 18 (100%+)
+88,637, Ive been backordered since 4/16/14
boudin4evr is offline
Old 06-26-2014, 06:15 PM
  #3351
STLNLST's Avatar
Trader Rating: 32 (100%+)
Originally Posted by masin14
Not for me. There is no play or any kind of binding either. Just make sure you use the washers.
See you Saturday. Let's end then points series on a good note
STLNLST is offline
Old 06-26-2014, 07:13 PM
  #3352
Trader Rating: 17 (100%+)
TIA!
I drilled blanks that came with the kit. I tried 3x1.4 and it was a bit more nervous with the same shock oil I am running with the 3x1.3 (37.5/30 Losi). If you go 1.4 I would go 40/32.5 Losi.
AlderBoy is offline
Old 06-26-2014, 07:36 PM
  #3353
Suspended
Trader Rating: 1 (67%+)
Are the pistons the same size as the standard associated sizes?
rcgarrettp9 is offline
Old 06-26-2014, 08:00 PM
  #3354
Rybeau40's Avatar
What is the difference between the 3 hole vs. the 4 hole. I just can't seem to get the shocks working right. I've tried two hole and 4hole setups and varying weights. Not found it yet.
I run on a bumpy track with some larger jumps. Clay/dirt mix medium to high grip depending on water in the track.
Rybeau40 is offline
Old 06-27-2014, 12:11 AM
  #3355
Dirtburners or Clubhouse?
Jason Snyder is offline
Old 06-27-2014, 06:22 AM
  #3356
Rybeau40's Avatar
I run at Clubhouse. 3x1.4 work great in my 2wd mod mid. With the pistons provided and the 1.6 I drilled with the d413 are just not dialed and various types of pistons setups so far aren't working well in the HB.
Lots of slap and the many bumps make the car handle worse then it should.
Rybeau40 is offline
Old 06-27-2014, 08:54 AM
  #3357
This is 2 x 1.6 with 37/30!
+ YouTube Video
or in HD here: http://youtu.be/CZ0dys5LKI8
Unfortunately you're going to have to compromise somewhere. When the track is bumpy you want to avoid pack.....which is what you need when the car chassis slaps off of a jump.
Have you tried something like stock pistons with REALLY heavy oil? It should give the car heavier static damping but won't pack up as aggressively!
Old 06-27-2014, 09:21 AM
  #3358
Tech Legend
Wild Cherry's Avatar
try
Front
2 x 1.5 , 35w,orange k spring or red ae
Rear
2 x 1.7 , 30w or 32.5w, gold k spring or ae green or white
Wild Cherry is offline
Old 06-27-2014, 09:28 AM
  #3359
Originally Posted by Wild Cherry
try
Front
Rear
WC....if he's having problems chassis slapping with 2 x1.6
a 1.7 with 32 in the rear isnt gonna be heavy enough....
My car is 30 with a 1.6 and still feels like it could stand to be a bit heaver like 35
I do agree with your spring choices though
Old 06-27-2014, 09:42 AM
  #3360
Tech Legend
Jason, don't own one, but helping tune a team mates..
Yes , 1.7 won't help um stop slapping , nor will 1.6 or even 1.5..
He's going to have to improved his driving , not to over jump the landings & down hill all the jumps.
Tuning for landings for reduce slapping only makes for poor performance on the rest of the track.
