Hot Bodies D413 1/10 4WD Buggy
#3361
Jason, don't own one, but helping tune a team mates..
Yes , 1.7 won't help um stop slapping , nor will 1.6 or even 1.5..
He's going to have to improved his driving , not to over jump the landings & down hill all the jumps.
Tuning for landings for reduce slapping only makes for poor performance on the rest of the track.
#3362
#3363
#3364
#3365
#3366
#3367
ha !
I don't think so just yet...
One of the reasons I have a interest in this platform is because it incorporates a lot of ideas I would of used myself on the b44...
So I try driving the HotBody each week judging or comparing to my Ae.
#3368
I love AE and Kyosho shocks. Not loving these ones though!
I'm going to try 1.6 again, but this time try 40 front 35 rear since the heat is gonna be upper 80s next in the coming days anyhow. Right now I'm stuck with the stock HB springs or HB red fronts.
Thanks, Jason, I'll give the original setup I had a go again, but with heavier oil this time.
#3372
Rybeau
Sounds like your outdoors, instead ?
Use
Front
Orange k spring & 1.5 x 2 taper piston 35w
Rear
White k spring & 1.7 x 2 taper piston 30w
Use Ae
Red front & Green rear if you don't have the k springs.
Use
Front
Rear
Use Ae
#3373
New to 4w buggy's... Why do you want a softer shock in the rear? Seems like the opposite on a 2w buggy?
#3375
Jcozz
Believe the 2w has more weight on the rear suspension then a 4 w & why 4w uses a softer rear suspension ..
