Hot Bodies D413 1/10 4WD Buggy >
Like Tree66Likes
Old 06-24-2014, 10:33 PM
  #3331
gticlay's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Jason Snyder
actually aluminum traditional style caps are coming!
No idea when.....but they are coming.
Also, why not drill a hole through them, run a longer screw and use some nuts to ensure they don't pop off?
gticlay is offline
Old 06-25-2014, 04:54 PM
  #3332
if you have motor temp problems, heres the solution. The difference is huge and the fan will never come out.
http://www.warny.pt/store/hot-bodies-d413-fan-rx-plate
nicmo is offline
Old 06-25-2014, 07:04 PM
  #3333
Trader Rating: 23 (100%+)
How is the fan held in position?
scteonoffroad is offline
Old 06-25-2014, 09:42 PM
  #3334
Rybeau40's Avatar
Will another brand 3x1.4 pistons work in the HB shocks? Also, anyone tried to mount another brand of shock on this thing with any success?
Rybeau40 is offline
Old 06-25-2014, 10:24 PM
  #3335
So Far no.....the hole in the center of the piston is too small....I just drilled my blanks today!
I made a jig to drill pistons..If I get time tI'll try to print a bunch out...
+ YouTube Video
Jason Snyder is offline
Old 06-25-2014, 10:55 PM
  #3336
Trader Rating: 22 (100%+)
Actually yes, I'm using the associated 3×1.4 with zero problems. just use both of the washers for the piston, pull the piston all the way down into the shock body and then tighten down. it works and fits perfect for me.
masin14 is offline
Old 06-25-2014, 11:16 PM
  #3337
Doesnt the shock shaft wander around inside the piston? the hole in the HB piston is much smaller.
Old 06-26-2014, 05:52 AM
  #3338
Rybeau40's Avatar
I'd like to find out for sure. Also, has anyone tried a different brand shock?
Rybeau40 is offline
Old 06-26-2014, 09:33 AM
  #3339
boudin4evr's Avatar
Trader Rating: 18 (100%+)
+ YouTube Video
NICE WORK J
boudin4evr is offline
Old 06-26-2014, 09:39 AM
  #3340
Not for me. There is no play or any kind of binding either. Just make sure you use the washers.
masin14 is offline
Old 06-26-2014, 09:48 AM
  #3341
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
+ YouTube Video
Very cool!! What brand 3D printer is that? Was that in real time or sped up? Keep up the great videos, thanks!
Bman's 3XNT is offline
Old 06-26-2014, 11:42 AM
  #3342
the incubus's Avatar
Trader Rating: 17 (100%+)
+ YouTube Video
Excellent idea Jason!!!
That's precisely the type of ingenious little ideas I conjure up in my brain all the time. One suggestion though is to make the jig a tad taller on the guide side and don't go so far past the piston because the bit eats a bit of material off the jig. Just drill til it punches through and keep the power on as you pull out of the jig so as to pull any burrs with it.
the incubus is offline
Old 06-26-2014, 12:01 PM
  #3343
Originally Posted by boudin4evr
NICE WORK J
Thanks guys...I'm using a printrbot simple metal
Heres a link to my machine: Its a new channel....havent promoted it yet....but I'm gonna start promoting it pretty soon.
+ YouTube Video
Old 06-26-2014, 12:57 PM
  #3344
Rybeau40's Avatar
Originally Posted by AlderBoy
Looking good Tim!
Here is my Norcal setup for reference too.
http://www.petitrc.com/setup/hotbodi...ies2014050507/
Took this from an old post obviously, but what type of 3X1.3 pistons are you running? (Brand wise) I have no more spares for drilling and want to put in 3X1.4, but need a reference to what will work in these shocks.
TIA!
Rybeau40 is offline
Old 06-26-2014, 01:01 PM
  #3345
Trader Rating: 149 (100%+)
I am using the AE SC10 shocks
skyline1015 is offline
