TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 04-22-2014 | 01:07 PM
  #1756
Casper's Avatar
Originally Posted by Tarimon
Casper, what´s about the clutch system? Can you tell something about it? It is mentioned in the manual, that there sometime something could be...
It is something they are testing now and sounds like may be out soon. Something Adam likes for loose tracks or blown out conditions to soften the bottom end punch of an electric car to make it feel more like a nitro. Not something I want but I am an electric guy so...... Each there own. Adam knows what he is doing.
Originally Posted by dodgeguy
I have both and they are not the same. The nitro conversion is a better drive. The E-3.0 is very ridged and does not seem to handle the rough stuff as well.
I am all most tempted to get a nitro chassis and conversion for mine.
The e-buggy may be a little siffer. I was developed for indoor running as well as outdoor. There are always trade offs for running in different conditions for the stiffness of a chassis. The e-buggy has proven to work well indoor as well as Phend winning the national title with it outdoor on a slick track.
Casper is offline
Old 04-22-2014 | 01:48 PM
  #1757
What size hex and nut driver do I need for this buggy?
kahuna2793 is offline
Old 04-22-2014 | 01:51 PM
  #1758
Salkin's Avatar
Page 10, top of page:
http://www.tlracing.com/ProdInfo/Fil...002_Manual.pdf
Salkin is offline
Old 04-22-2014 | 04:00 PM
  #1759
clutch setup adam running how does he brake?
pat dillon is offline
Old 04-22-2014 | 04:19 PM
  #1760
Durocken's Avatar
It's always engaged, you can adjust the slip like a slipper clutch
Durocken is offline
Old 04-23-2014 | 03:33 PM
  #1761
Tarimon's Avatar
Questions??
Originally Posted by XXXDad
I often see that guys use the rear E-Tower on the nitros, but Drake use the Nitro-tower on his E-Buggy...
Tarimon is offline
Old 04-23-2014 | 11:33 PM
  #1762
Salkin's Avatar
As I understand it, the only difference between the E and nitro tower is some additional holes in the E tower.
If Adam Drake does not use these new holes in the E tower, then there would be no difference between using the E or nitro tower.
I guess?
Salkin is offline
Old 04-24-2014 | 02:35 AM
  #1763
maddog9's Avatar
I guess?
Hes roughly in the 4 hole of an e tower.
maddog9 is offline
Old 04-24-2014 | 09:26 AM
  #1764
How the 8ight e 3.0on indoor clay and outdoor loamy ? What does this buggy do well and what does it lack if anything at all? How does this compare to tekno and mugen? Trying to make my mind up? No local 1/8 parts at the tracks I run. but 8 -12 buggy out every week.
Old 04-24-2014 | 09:41 AM
  #1765
symmetricon's Avatar
I like mine 10x more than I liked my eb48. It is much more stable. It is easy to achieve a locked rear end while still having plenty of steering....
symmetricon is offline
Old 04-24-2014 | 12:37 PM
  #1766
Tarimon's Avatar
Surely no E-Tower on Drakes car...compare!
Tarimon is offline
Old 04-24-2014 | 12:40 PM
  #1767
Casper's Avatar
The Nitro tower works with different camber link options. They are interchangeable.
Casper is offline
Old 04-24-2014 | 01:38 PM
  #1768
This is quite the opposite of what I'm trying to achieve.. cos I'm an electric driver and just recently decided to get a 3.0 nitro buggy, I'm trying so hard to set it up like my 3.0e. For me the biggest thing I miss (apart from the more direct/responsive feel) is the drag brake.
my 2c;
I don't see myself ever needing a clutch of any sort on the 3.0e, adjusting punch or even just adjusting the way you throttle up seems like a better option to me.
akshayp14 is offline
Old 04-24-2014 | 01:43 PM
  #1769
maddog9's Avatar
Theres a lower hole drilled out just like his nitro car here. It lines up roughly with the 1 hole on the ebuggy tower.
maddog9 is offline
Old 04-24-2014 | 01:49 PM
  #1770
maddog9's Avatar
my 2c;
You can set your nitro brakes were the rear brakes actually just start to rub not lock but where they will be engaged when you get off the throttle and slow the car like drag brakes do. You can adjust with your turnbuckle linkage.
maddog9 is offline
