TLR TEN-SCTE 2.0 Kit Thread
#7576
Hey guys I just built my new SCTE 2.0...love the truck but I have a few questions. I noticed that my off power steering is weak...any recomendations on a good setup to run? Also does anyone know what temperature the RX8 gen 2 fan kicks on at? I didnt have time to mess with the modes/settings yet on the RX8, just plugged in the fan and ran it.
#7577
#7578
If anyone is in need of a nice clean roller shoot me a PM, selling my SCTE 2.0
#7579
ok I got this car handling pretty decent but rear end is a tad loose coming out of the corners. I went to 5-5-3 diff fluid, and stock front and rear springs. I was thinking about going black springs up front, and silvers in the rear, with 5 pistons in rear.
Im loving this truck so far, so glad I bought it...only thing I am not liking is that all 3 of my diffs seem to be leaking and I cant understand why. Im going to change all the fluids tonight to see how low they are again. They have 3 solid days of practice on them now.
#7580
If Diffs leak in seam where the screws hold the two halves together check those screws and the gasket first. On new builds I suggest running the screws in and out a couple of times before final assembly. The screws might not be fully seated.
If the diffs leak at the out drives that would be the O-rings. The updated 2.0 diff cases should not have that problem.
Follow these steps to fix most diff issues. http://www.rctech.net/forum/electric...oof-diffs.html
#7581
Replacement chassis options
I noticed my chassis is bent. Mostly in the back. Are there any good replacement options other than the stock chassis. I saw an aluminum/carbon fiber one but have not seen anyone using it.
#7583
Use a 3.5mm reamer. I have a hudy one. Yes the inserts are available separately the part number is losb4114
#7585
I was looking thru some pictures of this 2.0 and seen were someone had moved the battery forward and the ESC behind it on the chassis would there be any real advantages to doing this? I kind of liked how it looked and I only race mine no bashing. I know it would require new holes for the batter mounts which is no biggie to do, just wasn't sure of a reason, or advantages as it has been only one I seen like that.
#7586
#7587
Rumor has it that the new truck is going to be called the
TLR SCTE 2.0 hacker07 Farewell Edition. That's what I heard anyway.
#7588
Better yet the TLR SCTE 2.0 Dunford Edition.
#7589
New owner
Picked up one of these from another forum member. Can't wait to get this dialed and on the track.
It's been a long time since i've dabbled with cars. As a kid i raced the original Losi JRX2.
#7590
Since i've been out of the game for a minute (more like 25 years). I have a lot to learn, but for starters what things should i inspect on my used truck? Thanks guys!
