TLR TEN-SCTE 2.0 Kit Thread >
Like Tree10Likes
Old 02-16-2015, 02:34 PM
  #7726
JR V's Avatar
http://www.amain.com/jconcepts-stick...-8-10g/p233933
or http://www.amain.com/losi-self-stick...ght-3oz/p13053
just a couple examples.
JR V is offline
Old 02-16-2015, 03:46 PM
  #7727
Originally Posted by YonkersRC
Stupid question...newer to racing...where can I get stick weights?
Sorry
The best place I found is a auto parts store and ask for a stick of tire weights
light is offline
Old 02-16-2015, 04:14 PM
  #7728
Default Stick on weight
Years ago there was very thin weight tape just for balancing tires. Now I see all they use is clay. I would rather use the firm tape for wheel balancing then clay. Heck I may wash it off when cleaning the tires.
Roken is offline
Old 02-17-2015, 04:45 AM
  #7729
maddog9's Avatar
Trader Rating: 30 (100%+)
Check jegs or summit racing equipment they sell 1/4 ounce stick weights
maddog9 is offline
Old 02-17-2015, 09:32 AM
  #7730
Casper's Avatar
Trader Rating: 34 (100%+)
Clay actually works quite well and also using some poster puddy works well. You can typically find it at a $.99 store or the like. Using something like lead tape will be hard to tune. Using clay or similar makes finding the fine balance easier and you can retune your tires as they wear if you choose.
Casper is offline
Old 02-17-2015, 06:22 PM
  #7731
ta_man's Avatar
Trader Rating: 168 (100%+)
You can get that self stick thin lead tape from McMaster-Carr (www.mcmaster.com).
ta_man is offline
Old 02-19-2015, 10:18 AM
  #7732
derekbsmith's Avatar
Trader Rating: 25 (96%+)
anyone know what inserts to use in the front hinge for least kickup and 1 degree toe out referencing
http://www.petitrc.com/setup/losi/se...ionals2011.pdf
The instructions are not clear at all. [LOSB4112]
Thx!!!
derekbsmith is offline
Old 02-19-2015, 12:47 PM
  #7733
Casper's Avatar
Thx!!!
That is an OLD setup.
I would guess as it is not noted you have 0 inserts in the the front end.
The rear end 1's up give you 3 deg of antisquat.
0's in the back give you 3 deg of toe in.
These are for the 8ight but the adjustments are the same for the ten
Rear pivots
http://www.tlracing.com/ProdInfo/Fil...structions.pdf
Front pivots
http://www.tlracing.com/ProdInfo/Fil...tion-Sheet.pdf
Casper is offline
Old 02-23-2015, 11:19 AM
  #7734
Originally Posted by hacker07
We are working on these as well as other goodies still. I am hoping we should see these by the end of the month or beginning of next.
Ryan,
Will the 2.3 front be sold individually or as a kit with asst front bars? Thanks
towertsk is offline
Old 02-23-2015, 12:34 PM
  #7735
Registered User
Trader Rating: 25 (100%+)
Originally Posted by towertsk
What causes the out drives to wobble? After inspecting my used scte the fronts and rears wobble horribly but the center seems fine. Is it the shims or poor assembly of the previous owner? How many packs would you expect to get from a new diff?
Tekno RC M6 Driveshaft & Lightened Outdrive Set
[TKR2210X]
RustyRC is offline
Old 02-23-2015, 12:36 PM
  #7736
fredmotokx's Avatar
How the new kit will be named, Ten-SCTE 2.5?
fredmotokx is offline
Old 02-23-2015, 01:12 PM
  #7737
No it will still be the SCTE 2.0 from what I understand it's not new its just updated parts/materials for better wear. and things like heavier swaybars for more tuning options and so forth.
It's not a redesign it's a refinement.
Dirtraycer is offline
Old 02-23-2015, 01:45 PM
  #7738
Casper's Avatar
Actually parts in the kit are the same as in same kit setup (read as swaybars and any option parts included in the box).
New vendor and retooled molds fix very minor issues in fit and finish of the kit. Same truck just new!
The thicker swaybars are option parts coming in soon from what Ryan has said. They are stuck in the harbor due to the longshoreman's strike/what ever they were doing.
Casper is offline
Old 02-23-2015, 05:45 PM
  #7739
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
just curious, is anyone running a carbon fiber chassis? is it better than stock?
JEFFs SC10 is offline
Old 02-24-2015, 09:13 AM
  #7740
Default Is this a TLR scte 2.0???
Hey guys I need your help identifying this scte truck. The guy that is selling it claims this is a TLR scte 2.0 but the chassis does not match the photos on the TLR website. Did the truck change chassis after the 2.0 revision? Any info would be great thanks.TLR TEN-SCTE 2.0 Kit Thread-losi-2.0.jpg
red100076 is offline
