Team Associated B4.2 Thread >
Like Tree4Likes
Old 10-08-2013 | 07:33 PM
  #10276
Grasschopper's Avatar
Originally Posted by lodhammerdin
That rule is for 2wd buggies. When the rule was first put out, It specifically stated that. 4wd is not under that rule.
Then the rule is totally misunderstood because this car was challenged by industry insiders (team manager) at the ROAR nats.
Whatever...I don't race in any ROAR sanctioned events so it is a moot point for me personally.
Grasschopper is offline
Old 10-08-2013 | 07:48 PM
  #10277
Anyone used a Ko-Propo servo in this kit?
Im looking at the 30100 RSx for it
ToxicBanana is offline
Old 10-08-2013 | 08:00 PM
  #10278
Just looked at the rule and 1/8 is the only exception. The HPI car is not "legal" according to the rules but like others have said, no one really sems to care anymore. The release specifically said they don't want cars designed around shorties. I don't think they saw shorties being embraced like they have been though, they can be had just as cheap as any other pack now.
DG Designs is offline
Old 10-09-2013 | 04:15 AM
  #10279
Jstall7543's Avatar
I run as much expo as I need for given traction on a given day, it varies every battery. my sweet spot is usually around +85 on dx3r pro. But there are times I'll go as low as +50. To avoid the trigger sawing I typically run 5 to 10% drag brake. The radio settings are available to help you and if you learn to use what you have you will be much happier with the results. Some people buy good radios and never even explore all the options, easy adjustments comes with time and familiarity of your radio. My slowest motor is a 7.5. I like my rc's to have big stones lol.
Jstall7543 is offline
Old 10-09-2013 | 04:23 AM
  #10280
Jstall7543's Avatar
This is the kit I slapped together lol I mean meticulously built. Paint job came out pretty wild looking. The windows and stripes are flat-ish black painted on the out side I ran out of satin clear. Ready to thrash! Kinda ugly but stands out pretty good.
Old 10-09-2013 | 05:00 AM
  #10281
Flip boy's Avatar
Yes i have that servo in one of my 4.2 buggies, very smooth fast not a power hog, but not a neccessity unless you just want to pay 200.00 for a servo lol.
Flip boy is offline
Old 10-09-2013 | 05:08 AM
  #10282
t0p_sh0tta's Avatar
I love Futaba's BLS451. I run it in all of my 1/10 scale stuff, and it's about $100 cheaper.
t0p_sh0tta is offline
Old 10-09-2013 | 06:35 AM
  #10283
BIGSKI15's Avatar
I have this servo too and really like it... its fast, quiet and has plenty of torque
BIGSKI15 is offline
Old 10-09-2013 | 07:02 AM
  #10284
Mizchief's Avatar
I've liked my Savox's i've used for awhile now. 1256 in 1/8 1258 in 1/10. They are power hungry but since switching to the Spektrum pro Rx I haven't had any glitch issues and didn't need a cap. Amain has/had them on sale for $50. I started using savox in heli's and airplanes so just stuck with them when I started racing.
Mizchief is offline
Old 10-09-2013 | 07:20 AM
  #10285
Originally Posted by Mizchief
Depending on your scale the phone can mess with the magnets and cause a false reading, so may not be the best standard. Many will come with a 100g calibration weight, nickels are also commonly used as they weight exactly 5g.
Well I broke out the nickles. Shop scale said 49.997g for 10 nickels...postal scale said 50g. I'm saying my scales are spot on.
So I just weighed my 17.5 B4.2 and it's light...like way light. I'm at 1460g with the body. That's with the centering kit, an AVID shelf for the ESC and with the body this time. I have 7g weights in the rear triangle and the FT ballast, does it make sense that I need to add an additional 40g just to get to the minimum?
Old 10-09-2013 | 07:39 AM
  #10286
Captcha's Avatar
if you are running a shorty pack, then yes.
I have a shorty pack and a short rx, I had to add 20 grams to be at 1504G. this is without the avid centering or shelf, but I run a novak gtb2 so that is heavier than a tekin rs
Might need to make a new name now, I am 6's all around.
Captcha is offline
Old 10-09-2013 | 07:45 AM
  #10287
Wildcat1971's Avatar
Um, I dunno, seems wrong to me. I am running 7g in the rear triangles, shorty, esc shelf, ballast, minimal wire and I am at 1520 with body and tires. That being said, my closed cell tires weight more than my open cell tires. But still 40 grams under with ballast and lead seems too light. I am running a LP servo also.
Wildcat1971 is offline
Old 10-09-2013 | 07:52 AM
  #10288
thecman26's Avatar
R/C Tech Elite Member
Good servo but VERY expensive, I use this and it is awesome, and a $71 not a bank account buster!
http://www.amainhobbies.com/product_...ium-Gear-Servo
thecman26 is offline
Old 10-09-2013 | 07:53 AM
  #10289
I'm running a Viper VTX10 ESC which is claimed to be 50g without wires I think. It's beefy. But yes shorty packs.
This is with closed cells all around. It is with the Triad which is light and an AL pinion but how much weight am I really saving with the AL pinion? A couple of grams maybe. Oh yea this one is with a Solar D770 which is pretty light...and the transponder isn't in the car...but again, that's only another 5g (just weighed the one from the mod car).
Ok so where do I add the weight? 10g in each corner of the car? Try to get the balance perfect? Slap it in the tray? And if the answer is slap it in the tray then what's the point of running shorties?
Old 10-09-2013 | 08:10 AM
  #10290
Captcha's Avatar
I dont know then, I would grab another scale and weigh it just for s&g's.
I teched a guy this weekend that was at 1499 on the nose full trim, so he went from a JC body to a proline body and came back at 1505. BUT i don't believe he runs the rear ballast weight either.
As far as where to add weight, I would add it in the side trays, exactly in the middle of the car, right against the battery tray. How to find this. Measure the car nose to tail, find the half mark, add the same amount of weight on each sid in the side trays right against the battery tray. UNLESS you already have more weight on one side than the other, then if that is the case, I would add accordingly to make the car as balanced left to right as possible.
Captcha is offline
