Team Associated B4.2 Thread
And for those looking to drill the pin holes on new parts get the #33 drill bit...#34 is a smidge too big.
Good Morning,
I've taken your pic and marked it up so that you can see that the Exotek Hub is indeed at the C height. The difference between C and A height is only about 1.75mm- about the thickness of a Nickle
You have to look at the center line of the stud ball.
Don't just go by visuals- you must actually measure the parts with some good calipers- center line to center line.
Any way hope that clears it up for everyone.
Cheers
Cheers
well guys i installed he dubro ends on my car vitually no slop only slop was in the c hubs and and the arms so just a bit the ends need worked in a bit yet but it is SUPER consistent, ran that with the jconcepts finisher body and wing didnt cut the body to the lines made it as tall as possible drove really easy compared to the proline bull dog or vortex i ran that with the jconcepts wing yet again full 3/8 above the first cut line so its level with the sides drove really consistence and easy super awesome got 2nd to a sponsored guy do to traffic, and i started 4th good night overall need new rear tires, which are coming in wed but my old ones are bald so its needed
Can anyone tell me the size of the bleed screw o rings that go on the cap of the 12mm shocks? That’s all I need, I can order the whole rebuild kit if I need to. Just looking for that o ring tho. Maybe a aftermarket set that is a little stronger? Thanks.
I recently bought the rebuild kit for the o ring the problem my friend told me is that it is getting tightened down too far, "tighten it down until it stops it self barely using any finger strength, i learned the hard way i guess you have as well, rebuilt my shocks with his method, not leaking and o rings are still good
lol okay, thanks! learning pains ha ha. Is it normal for them to leak a little over time and or get air into them? How long should it take before you need to replace the oil or top them off and re bleed them? Seems for me after a good full day of practice or a race that i will start to notice the end of the shock a little wet and some air. I then replace the oil. I have only ran the car 4 times so far.
i like running the ball diff on low-med tracks because it feels better with the gear diff on high traction surfaces(after i tune the car in with the ball diff) it seemed to have more rear end rotation around tight 180 corners took away maybe 5% on power steering as well both good things for me i started with 5k oil and it works well i might be going a bit lower a mix to get 4k um for looser tracks you might want to start at like 2-3k weight asc oil also if youll have to get a triangular file an file down the flashing on one side of your gear diff FLUSH with the other teeth, if it isnt stable on power go to like 5k and if it nees more rear grip to go like 1k or 80 weight oil and try that
When i say leak i mean a very, very small amount. Not noticeable to the eye by taking the cap off. I can just see a very little bit between the retainer clip and the end of the shock after a weekend of running.
I run both my B4.2 and SC10.2 without the o rings with no leak issue at all. no need for them. Just snug the screw when done bleeding.
Hello all. I picked up a B4.1 chassis on ebay then bought parts from amain to complete the roller. The battery brace I bought is just barely too short. I got the carbon brace for the b4 but amain shows it fits all b4s.
How can I find out what chassis I have? What is the difference between the +8 and a reg b4 chassis? Thanks for any info.
4Likes
