Team Associated B4.2 Thread >
Like Tree4Likes
Old 10-06-2013 | 04:34 PM
  #10156
Matt Trimmings's Avatar
Make sure your diff is tight enough before you set your slipper. If your buddies b4 is amazing you should be checking his car over to see how its setup compares to yours.
Matt Trimmings is offline
Old 10-06-2013 | 04:39 PM
  #10157
Wildcat1971's Avatar
Originally Posted by UrabusDenis
Hi guys,
I bought a used B4 Factory kit (old one) for fun on the track (since there is no class) between runs with my 1:8 eBuggy which is my primary car. I can't brake with this car after the long straight without spinning completely every time- the shocks (with proper oil, green/brown springs) and diff were all rebuilt before the run. I then tried the car of my friend, which is a B4.1 and wow his car was amazing- so much fun to drive it made me estatic thinking my car hopefully be like that when its sorted out. Any ideas where the problem could be? I will open the transmission tomorrow, just wanted to check if any 2WD guru can see the solution instantly.
Also, I can't seem to setup the slipper properly- when using the method of holding the wheels and setting up for the front to raise 3 inches, my car doesn't raise at all even when the slipper is almost fully tight. Any ideas here aswell? I'm pretty experienced in 1:8 eBuggy and 1:10 TC but I must admit I am faced with some pretty novice situations and questions with 2WD buggy
if your running a 17.5 its harder to raise it 3 inches. I only shoot for 1 inch on my with a triad
Wildcat1971 is offline
Old 10-06-2013 | 04:43 PM
  #10158
silveraider14's Avatar
If you have 100% brakes that could be the problem also. I run maybe 60 but I try not to use them
silveraider14 is offline
Old 10-06-2013 | 05:15 PM
  #10159
Originally Posted by silveraider14
I shaved the plastic one and have been fine for 3 weeks with plenty of tumbles and getting hit by short course trucks.
I have not needed to use 27.5 weight yet
Im pretty close I think to what I want if I go to 27 in the rear and change from 1.6s to 1.4x3s what changes will it make. Im still learning what the 3 holes are like.
jswo is offline
Old 10-06-2013 | 05:21 PM
  #10160
You will have more weight transfer to the rear so it will have more rear bite
Old 10-06-2013 | 05:28 PM
  #10161
rc car guy's Avatar
Hi guys,
one turn your steering down if you need more steering change tires till that works, 2 once you get the right amount of steering and still spinning out change rear tires 3 if that doesnt work start turning down your brake to where its controllable slide/turn, this is the basics
rc car guy is offline
Old 10-06-2013 | 05:37 PM
  #10162
Sounds good, depending on tires sometimes had to much steering
jswo is offline
Old 10-06-2013 | 05:41 PM
  #10163
Yeah you gotta have the right tires forsure
Old 10-06-2013 | 05:51 PM
  #10164
Just put in the centering kit and now the right front is 13.5g heavy and the right rear is 4.2 heavy. Before I weighed it I cleaned it real well and checked shock collars with calipers. Any ideas.
jswo is offline
Old 10-06-2013 | 05:57 PM
  #10165
DanielC.'s Avatar
Not sure if it's been mentioned on here yet, but give the new TLR machined 1.6 pistons a try. Much tighter fit than the AE machined pistons both in the shock body and on the shock shaft. My car jumps like an RB6 with these suckers.
DanielC. is offline
Old 10-06-2013 | 08:16 PM
  #10166
mick33b4's Avatar
Originally Posted by RapidRC
Next weekend I will be racing on an outdoor track and am hoping to get some set up advice. It is bumpy, big jumps, hard packed, dusty and can be very loose. When I've raced there before rear traction was the issue. I don't have a lot of time to test so suggestions will be greatly appreciated.
I run on a track like this. This weekend switched the car around back for indoor clay, so the notable changes are top of mind.
- 3.5 deg rear toe block
- Open pistons with 30 wt.
- Black Front spring, Green Rear spring
- One camber washer front, two rear
- Unshaved rear mount, A hub mount
- Full pack
- Battery FORWARD
- 2 deg camber front/rear
I find outdoors dusty I'm trying to take steering out of the car. The rear end is always unexpectedly coming around. I found rear toe to 3.5 helped stabilize a lot. Black springs and roll axis tipped rearward (compared to the kit setup of 2 washers front and 1 rear) seems to help. Also, battery forward seems to help with the corner exit over-steering.
My tire picks
Front: grooves
Rears:
- For packed with loose dirt: double dees or 3Ds
- For packed with more loose dirt: bow-ties
- For loose: Goosebumps or IFMAR Studs
Double dees are great if they are watering. Bow-ties pretty much work OK for all of the above. They also seem to wear more slowly than double dees.
mick33b4 is offline
Old 10-06-2013 | 08:30 PM
  #10167
does anybody make hubs that are black or silver?
can I de anodize the exotek hubs?
Old 10-06-2013 | 08:32 PM
  #10168
When running 17.5T is it still wise to use the rear ballast weight?
ToxicBanana is offline
Old 10-06-2013 | 09:36 PM
  #10169
I have always used it and I run 17.5.
my car weights in at 1554g
Old 10-06-2013 | 10:09 PM
  #10170
ok I am pretty sure I do not have a +8 chassis. The stock b4.1 body part #9792 fits the chassis fine. How is the b4 battery strap too short? It is less than a MM too short. And thank you so much for the info that the +8 chassis is 8mm longer than a stock chassis that helped so much.
Rawwolf is offline
