Team Associated B4.2 Thread >
Like Tree4Likes
Old 11-06-2013 | 05:29 PM
  #11026
Originally Posted by Jake S
not worth the price of upgrading, sell your old b4 to someone at the track, and buy a new b4.2 lol
big bore shocks, alu steering rack, multi pad slipper, longer chassis, longer battery strap, alu hex, alu rear hubs.
So using my B4 and fixing it when necessary might prove difficult. Are parts still available?
Tibbar110 is offline
Old 11-06-2013 | 05:30 PM
  #11027
Originally Posted by kyoshoracer77
Hey guys I am running shorty pack for the first time in my b4.2 an I got my receiver in the Lipo tray and the ESC on a shelf.
Shock are set up like the book set up but I put the tapered 1.6 in with 32.5 front and 32.5 rear . My question is going in to a sweeping turn the rear washes out?? Every else the buggy is fine!!!!
The track is a in door, cold, clay wet. Tire front and rear is a green barcode and a m4 suburbs.
Might want to look at softening up the rear. I run 30wt in the rear with green springs and regular 1.6 pistons
fivepointnine is offline
Old 11-06-2013 | 05:33 PM
  #11028
Guest
Do u think the tapers are hurting more than helping??
All I got for springs is the factory kit springs.
kyoshoracer77 is offline
Old 11-06-2013 | 05:35 PM
  #11029
silveraider14's Avatar
I would drop the rear shock oil weight to 30 and try it first.
don't think different pistons would solve that problem
silveraider14 is offline
Old 11-06-2013 | 05:38 PM
  #11030
Guest
OK will do.
Old 11-06-2013 | 05:47 PM
  #11031
mashimarowu's Avatar
What size pistons, oil, and shocks are good start off for a full stick pack? I feel the car likes to slap more off a jump instead of being plush landing and driving off. Is there one part I should work with more first such as using smaller size pistons or higher weight oil?
mashimarowu is offline
Old 11-06-2013 | 05:55 PM
  #11032
trixter91's Avatar
1.6 pistons 30 up front 27.5 in the rear. 24mm ride heigth
trixter91 is offline
Old 11-06-2013 | 06:10 PM
  #11033
Wild Cherry's Avatar
Tech Legend
Taper makes the car more reactive , better for sharp corners but harder to drive.
Flat piston will drive smoother & easier for you.
Easier to drive will work best for someone new .
As you gain experience you will learn to make the car faster but not necessarily easier to drive ...
start with Green spring front & back
2 x 1.6 flat
32.5W front >>Med Traction
30W rear or 27.5W for extra traction
Wild Cherry is offline
Old 11-06-2013 | 06:31 PM
  #11034
Guest
2 x 1.6 flat
Thank u cherry!!.
Ur right the the buggy felt good on the infield. It would turn tight!!!!!! Real tight!!!!! Jumped good and level. Very quick to transion from left to right hand turns. No pushing at all. I thought about taking steering out by the radio. I never had a b4 turn like this turned!!!!
Old 11-06-2013 | 06:36 PM
  #11035
Guest
Default springs
Now this might be dumb but what color of springs would I need for the buggy front an rear without buying the package sets?
I got the black front and white rears.
I need green ft an green rr. What else do I need and for the b44.2 stock is blue ft and white rr for springs?
Old 11-06-2013 | 07:03 PM
  #11036
ryanpatrickgore's Avatar
White front and your probably good to go.
All you really need is white and green front and rear.
Maybe blacks if you have low traction
ryanpatrickgore is offline
Old 11-06-2013 | 07:57 PM
  #11037
BLKHAWK's Avatar
Hey guys, im looking for more steering the car has great fwd traction and side bite.
running A hubs with a 2mm spacer under the ball stud on a non shaved brace as well as a 2mm spacer in the front. rear shocks are 27.5 oil 1.6 taper piston white spring, front shocks are 32.5 oil 1.7 flat piston and green spring. full pack, bar codes on the front with stock foams. any tips would be greatly appriciated!
BLKHAWK is offline
Old 11-06-2013 | 08:05 PM
  #11038
Guest
How much lead do u have in the buggy I put 3pcs -1/4 ounces in front of my servo. And are u running the same front and rear tire as the fastest guy on the track????
Old 11-06-2013 | 08:09 PM
  #11039
BLKHAWK's Avatar
The losi BK bar with an AKA red foam seems to be the ticket, last race TQ was a C4.2 with the same tire. running factory weight, 1 7g in each rear triangle and 14g behind the servo. battery is almost full fwd
BLKHAWK is offline
Old 11-06-2013 | 08:21 PM
  #11040
I have found Ion's have more traction (more steering) Barcodes a little less and scrubs the least (these push like crazy on my car)
you might try running trimmed rear inserts on your front barcodes too
I run a short lipo all the way forward, 7g weight in each rear triangle. My car is on the borderline of having too much steering
