Team Associated B4.2 Thread >
Like Tree4Likes
Old 05-12-2013 | 06:27 AM
  #5071
tedstryker's Avatar
last thing you want is not to finish a race from a popped ball cup....
tedstryker is offline
Old 05-12-2013 | 07:25 AM
  #5072
Venom1836's Avatar
I run the JC ballcups and they are just OK.
They pop off in a bad crash but seem to bend easy.
Venom1836 is offline
Old 05-12-2013 | 07:28 AM
  #5073
B.A. Racer's Avatar
Originally Posted by Advantage R/C
Ok, so quick question. On my buggy it is pushing wayyy to much in certain sections of our track barley clipping the pipe to get by, so my question is what can be done? I took the washers out from under the ball studs up front, but still pushing. Anything else I can try?
If it is that bad...it is most definitely your tires. No questions asked.
B.A. Racer is offline
  #5074
CHIZZLE's Avatar
Originally Posted by Wild Cherry
Stock cups can make it easier to get a perfect alignment from kit directions and a set of calibers
Never understood why someone would actually measure the turnbuckles when assembling before putting them on the car. Personally, I put a little bit of Chapstick on the threads and thread the ball cup on and off a couple times then put it on the car. Adjust the toe/camber settings from there.
CHIZZLE is offline
Old 05-12-2013 | 07:42 AM
  #5075
lodhammerdin's Avatar
Originally Posted by shagnat
I hope RPM ballcups are not garbage. I've read dozens of posts that they are THE ballcup to use. I've got 4 sets of them ready to install on various cars/trucks and would hate to be disappointed in them.
Now I don't know whether to sell them, junk them or use them....... *sigh*
I personally like the RPM ballcups being that they are longer than the stock AE ones. Were I race (outdoor 1/8 scale dirt track thats rough and bumpy), I've never had a ballcup come off. I do have the TiNi ballstuds and I always put just a little bit of black grease inside the ballcups to help prevent binding. When I say a little, I mean like less that a drop.
lodhammerdin is offline
Old 05-12-2013 | 08:44 AM
  #5076
D.Martijn's Avatar
(Double post)
Sorry
D.Martijn is offline
  #5077
D.Martijn's Avatar
I have only broken one stock ballcup so far. Made an unlucky crash..
Yesterday I replaced my ballcups to the old AE ballcups.
The older ones seems to be stronger
Old 05-12-2013 | 08:58 AM
  #5078
bds81175's Avatar
Moderator
I'd have to agree with BA Racer on the pushing. You can hide a lot of other issues with the right tires. Or you can make a car with the perfect chassis tuning handle like a 2000 Chevy Astro van (I own one...not pretty). If you have decent tires in the back and a crappy diff it will push like a barge and there won't be anything you can do about it.
bds81175 is offline
Old 05-12-2013 | 09:02 AM
  #5079
SCDriver's Avatar
I have used RPM cups for the last year or more on my SC10's and I have never had a problem with them. I am 100% confident they will work just as well on my buggies.
SCDriver is offline
Old 05-12-2013 | 09:08 AM
  #5080
Wild Cherry's Avatar
Tech Legend
[QUOTE=CHIZZLE;12143111]Never understood why someone would actually measure .
Chizzle
Measuring is the easy way to keep both sides (left & right) equal .
This way your ride turns the same either direction.
Also drives straight with no pull
Wild Cherry is offline
Old 05-12-2013 | 09:13 AM
  #5081
Lunsford ballcups hands down
Toyman is offline
Old 05-12-2013 | 09:17 AM
  #5082
Suspended
Racing at SRS and everybody uses the exact same tires. Rips.
Advantage R/C is offline
Old 05-12-2013 | 09:40 AM
  #5083
CHIZZLE's Avatar
Chizzle
Meh, I disagree. Zero out your servo on the radio, square up the steering rack as close as possible and install the horn on the servo, use the sub trim to center it up perfectly. Then, adjust your links for toe and camber. I check and recheck my toe and camber on a constant basis. If you only do it the one time when you build your car, I guarantee you it's off.
CHIZZLE is offline
Old 05-12-2013 | 09:42 AM
  #5084
CHIZZLE's Avatar
I used Holeshot fronts there.
CHIZZLE is offline
Old 05-12-2013 | 10:06 AM
  #5085
Suspended
Thank you, some other tires! I asked Mike and he said ya I don't have traction either but these are the right tires. Ordering some right now.
