Team Associated B4.2 Thread
#4996
Note: this change can only be made if you downloaded the newest hotwire software. Good luck!
#5000
Ya a flat piston has the same compression/rebound, while a tapered piston will travel quicker whichever direction the taper is. The way I think of it, which I may be wrong, with the taper facing down, the shock will pack faster and rebound slower. So on a med/high bite track, shocks compress and the car will remain in that stance for a little longer which will give you more traction.
Right?
Right?
#5001
AE's tapered pistons have larger holes than the stock pistons. I had to go up 1/2wt all the way around with the tapered 1.6 pistons. I have them set to rebound faster (taper down), but I lost pack when switching.
#5003
I think that was to be expected because the holes are slightly bigger because they are machined.
#5004
What good is a 1.6 piston, where nothing is 1.6? I didn't expect the holes to be bigger, I expected the entire piston to be rounder and fit more precisely in the bore. This would've increased dampening, like the old red pistons I ran in my V2 shocks.
#5007
#5008
I'm Hunter, goofy looking guy that sits in the front by sean and Jim.
#5009
0 rebound. After the initial bleeding you need to pump the shocks to build up a little pressure, then bleed them again. After that they should have 0 rebound for awhile. Come find me if you have any issues. I'll be on the carpet side this weekend since I'm running sedan as well.
#5010
Thanks to everyone for the tips on the bodies, I decided to go with the finnisher from jconcepts. Ironically the current body I am using appears to be a bulldog one. Should be able to get some good comparison.
4Likes
