Team Associated B4.2 Thread >
Like Tree4Likes
Old 05-09-2013 | 10:46 AM
  #5011
B.A. Racer's Avatar
First off, a body isnt going to make or break the way a car handles. It isnt going to make a car great if its already bad. And if you know any changes, it will be minuscule at most!
The past 3 weekends i have been playing around with the 3x1.4 pistons. My local track is a pretty bumpy track. And the 3x1.4 pistons soak up those bumps really well! But i felt like they were too soft in some areas also. I ran them back to back with the 1.7's multiple times....The 1.7's felt faster but was a little more inconsistent and on edge through the bumps while the 1.4 felt like riding on clouds. But again, there were certain areas where i did feel that the 3x1.4's were too soft. While running the 1.4's, i had to go up in spring rate in order to keep the buggy from dumping and being grabby. To me, at my local track, 1.7's were faster while the 3x1.4's were more consistent. If my track wasn't bumpy and rough, i would have definitely went to 1.7's and possibly tried the 1.6's.
This weekend will be the first weekend trying the 1.4's outdoors. I feel like they have potential, but for some reason i feel like the 1.7's will be my go to piston. Final conclusion.....i feel that the 3x1.4's pistons are a good tuning aid, but at the end of the day, i feel that the 1.7's are going to be my go to piston. But as everyone knows, in 2wd buggy, shocks are possibly the most important adjustment on the car aside from tires, and its a never ending battle with pistons, oils, and springs.
B.A. Racer is offline
Old 05-09-2013 | 10:48 AM
  #5012
t0p_sh0tta's Avatar
Originally Posted by ChrisAttebery
Or it could be because the holes are slightly shorter. Did you actually measure them or do they just feel like they have less pack?
That could be possible. I didn't measure, but I'll try tonight.
t0p_sh0tta is offline
Old 05-09-2013 | 11:31 AM
  #5013
Jake S's Avatar
i have made a few changes since 1.4s..
went to black front springs, with green rear springs.
3x1.4 pistons 32.5wt front / 30wt rear
car feels amazing, it does everything well imho.
also running b4.2 bulldog, and 6.5 stabilizer (all 90-deg gurney removed)
Jake S is offline
Old 05-09-2013 | 11:47 AM
  #5014
Wildcat1971's Avatar
I was actually planning to try that shock package this weekend.
Wildcat1971 is offline
Old 05-09-2013 | 11:55 AM
  #5015
Jake S's Avatar
i tried every combo of green/black fronts and green/white rears.... just ended up like'n black front / green rear the most with the 1.4s... greens where alittle soft so i went up from my normal 27.5 to 30wt in the rear.
Jake S is offline
Old 05-09-2013 | 12:23 PM
  #5016
MODELTECH22's Avatar
At my track, a medium bite medium size track not a whole lot of bumps, and smaller jumps i have been running 1.7 front rear with 37.5 front and 35 rear with green springs both front and rear and my car feels very good.
MODELTECH22 is offline
Old 05-09-2013 | 12:44 PM
  #5017
DanielC.'s Avatar
This combo is fantastic at my local indoor clay track along with c hubs/shaved brace
DanielC. is offline
Old 05-09-2013 | 01:32 PM
  #5018
Tony Rivas's Avatar
Shaved brace? Please do tell
Tony Rivas is offline
Old 05-09-2013 | 02:12 PM
  #5019
Matt Trimmings's Avatar
Check the first page of this thread and/or the first page of the http://www.rctech.net/forum/electric...4-1-ft-wc.html
Basically you shave the nub off the u brace where the inner ball stud mounts. This is normally used in conjunction with the C Hub mount which lowers the outside ball stud mount.
Matt Trimmings is offline
Old 05-09-2013 | 02:53 PM
  #5020
onefast8's Avatar
Matt, care to elaborate on what is actually going on when switching from a 2x1.6 pistion to a taper 3x1.4?
I'm really wondering what adding the extra hole does?
I would think that the taper makes the shock pack faster and rebound faster?
onefast8 is offline
Old 05-09-2013 | 07:22 PM
  #5021
Tony Rivas's Avatar
Thanks for the info Matt!
Old 05-09-2013 | 08:39 PM
  #5022
This might be a stupid question. But which washer is thicker? 0.030 or 1mm?
Thanks.
padjr1 is offline
Old 05-09-2013 | 08:40 PM
  #5023
CHIZZLE's Avatar
More in one direction, less in the other. You can mount it whichever way you want.
CHIZZLE is offline
Old 05-09-2013 | 08:41 PM
  #5024
CHIZZLE's Avatar
Thanks.
1mm=0.039
CHIZZLE is offline
Old 05-09-2013 | 08:44 PM
  #5025
Originally Posted by CHIZZLE
1mm=0.039
Thanks Chizzle.
padjr1 is offline
