Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-02-2013 | 06:41 PM
  #5761
Matt Trimmings's Avatar
Originally Posted by Venom1836
http://www.amainhobbies.com/product_...nsert-Medium-2
How many sets of tires can I get out of these inserts before I have to replace them?
Do I punch holes in only rear tires?
(I will stuff 3/4 of a rear foam in the front tires)
Do I punch holes in the front tires?
What size holes?
Thanks!
You are going to want these:
If you cant get those i would recommend the AKA stuff. If you use closed cell foam you will want to punch two 2-3mm holes in the tire (180° from each other). If you use standard foam then you only need the hole in the rim. Depending on the surface and how much you run the foams can easily last a couple sets of tires.
Matt Trimmings is offline
Old 06-02-2013 | 06:44 PM
  #5762
Suspended
What size holes?
Thanks!
Why rear foams in front tires? They make fronts. 2wd buggy I put 2 holes total. Each 180 degrees from each hole.
Team G Racing is offline
Old 06-02-2013 | 06:50 PM
  #5763
Because they are bigger and add more support to the fronts.
Old 06-02-2013 | 06:53 PM
  #5764
DanielC.'s Avatar
Try standard front foams on a high bite track, and you will understand.
DanielC. is online now
Old 06-02-2013 | 06:58 PM
  #5765
Suspended
Hm, intresting. Never thought about that. Might have to try that out
Old 06-02-2013 | 06:59 PM
  #5766
Suspended
I did at this years Cactus Classic I actually ran pretty good with them
Old 06-02-2013 | 07:01 PM
  #5767
Would have been better with more support. It is more of a middle ground between a std front foam and a closed cell front foam. I always shove at least 3/4 of a rear in my fronts.
Old 06-02-2013 | 07:05 PM
  #5768
What does the different springcups included in kit do? Droop adjustments?
Which one to start off with?
zzztech is offline
Old 06-02-2013 | 07:08 PM
  #5769
Venom1836's Avatar
Thanks!
I thought racers prefer the 3206-2 better in the rear tires?
What is 2-3mm equal to in inches of the punching tool?
Venom1836 is offline
Old 06-02-2013 | 07:09 PM
  #5770
Thanks!
I dont know...i use the one in the middle...maybe just smaller than the middle one. The 3206-3 has a rounder profile and fills the tire up better. the -2 is flatter.
Old 06-02-2013 | 07:10 PM
  #5771
Venom1836's Avatar
The different sized cups are included with the Big Bores so you can use the same length springs on truck or buggy. The medium sized ones are always used on the B4 I believe.
Old 06-02-2013 | 07:12 PM
  #5772
Run the middle ones. They are mainly desgined for use with the truck, buggy you will always use the middle. Its not a tuning option. They only made front springs and rear springs, no more truck fronts / buggy fronts. By running a longer cup on the truck you can use the same length springs and still achieve proper ride height.
Old 06-02-2013 | 07:38 PM
  #5773
Suspended
Did you win the a?
ifuonlyknew is offline
Old 06-02-2013 | 07:45 PM
  #5774
Skillz_B's Avatar
I believe the shocks internal spacers (limiter) adjust droop, I might be wrong though this is my first B4
Skillz_B is offline
Old 06-02-2013 | 08:33 PM
  #5775
Waflet's Avatar
Hideeho
Sorry ahead of time because I know it has been asked before but I couldn't find it in a quick search
What size are the bleeder screws for the BB's?
Waflet is offline
