Like Tree248Likes
Xray XB4 thread
Old 01-11-2016, 01:50 PM
  #9991
BentKa's Avatar
Originally Posted by jakeb
Hey All,
New to the Xray platform as I will be receiving an new XB4 in the next few days.
Looking through the manual I notice that there aren't any shock shaft measurements or free length measurements to get baseline droop setup, aside from the number of shims under the piston.
How are you all doing it? Are you just setting shock shaft length to one consistent measurement or are you using some form of droop measurement during final setup?
Thanks a bunch.
- Jake
Easy…..you build the shocks with the shock rod ends screwed on with no visible threads showing on the shock shaft.
Droop is then adjusted with shims inside shocks or if more droop is needed by unscrewing the shock rod ends 2-3 full turns.
Bent
BentKa is offline
Old 01-11-2016, 01:51 PM
  #9992
BentKa's Avatar
Originally Posted by crusty
What are you guys using for a fan mount on the xb4?
Double sided clear servo tape.
Bent
BentKa is offline
Old 01-11-2016, 06:11 PM
  #9993
Slapjack's Avatar
Trader Rating: 19 (100%+)
If using the 16 bulkheads on my 15 is all I need to do is dremel the towers to clear the added bracing on the 16 bulks?
Also, is it possible to just use 16 towers with the 16 bulks and not have to change anything else? Are the 16 towers any different than the 15 towers (other than the notches for the clearance of the bulk bracing)?
Slapjack is offline
Old 01-11-2016, 06:50 PM
  #9994
you can make the 16 towers work on a 15 but, yes you will need to do a little dremel work, more specifically the rear tower.
geometry is a little bit different with the 16 towers.
best bet is to get the 16 bulkheads and towers
punkracer24 is offline
Old 01-11-2016, 08:04 PM
  #9995
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Norse
I agree with you and the new the 3 pad slipper. I know some fellas whom are using Mczkune pads with the Optional 3pad slipper in their YZ4's in which they are having better than excellent results on everything from very low bite to super high and all between. I may try see if they have Mckune pads for the XB4 and try them out.
Looking forward to hearing your thoughts on how the medium flex chassis braces and side rails work.
Thanks Brother
I ran the medium braces and side guards today and they did exactly what Bent said they would. The car is easier to drive and not as twitchy. My fast lap was the same as with the hard parts, but I was able to drive hard without it feeling like I was on the edge of control. Thanks Bent. Good advice.
rcgod is offline
Old 01-11-2016, 08:09 PM
  #9996
STLNLST's Avatar
Trader Rating: 32 (100%+)
You won't be testing alone. I will soon have mine. We will have some fun 😉
STLNLST is offline
Old 01-11-2016, 11:15 PM
  #9997
BentKa's Avatar
You're very welcome
Bent
BentKa is offline
Old 01-11-2016, 11:17 PM
  #9998
A question, should the plastic rear chassiplate ( under the bulkhead) be used?
Anyone use the 3mm chassi?
volvofreak is offline
Old 01-11-2016, 11:58 PM
  #9999
BentKa's Avatar
No rear chassis plate for the '15 and '16
The 3mm chassis is an awesome upgrade for the '15 model when used on high grip carpet and astro tracks
Bent
BentKa is offline
Old 01-12-2016, 12:03 AM
  #10000
Anyone try rear motor yet?
LAGuy is offline
Old 01-12-2016, 12:12 AM
  #10001
Bent
Thanks bent for fast reply
Old 01-12-2016, 12:14 AM
  #10002
BentKa's Avatar
You mean the shorter rear center driveshaft and longer front to move the motor more to the rear ?
We only use the standard forward mounting unless we're on a really blown out dirt track.
On anything else we prefer the added steering of the standard layout
Bent
BentKa is offline
Old 01-12-2016, 12:18 AM
  #10003
I have used 3mm chassi now for a week and i agree its make the car so predictible in the steering. Just want to hear other persons opinion about this. How about 12' Alu casterblock?
Old 01-12-2016, 12:22 AM
  #10004
BentKa's Avatar
For astro and carpet we always run the 12* C-hubs, alu. ackermann bar and alu. rear uprights, no top decks and only the front steering brace to get maximum steering
I'm assuming you run carpet or astro ?
Bent
BentKa is offline
Old 01-12-2016, 12:29 AM
  #10005
Bent
Yes running on carpet. Ackermann plate, i have that but i have problem with bumpsteer. I have to put 6mm washer to make it work properly is that correct? Use 9' casterblock
