Like Tree248Likes
Xray XB4 thread
Old 11-10-2015, 01:23 AM
  #9241
Nat Maniac's Avatar
Originally Posted by BentKa
Please also read the answers to these posts.
You have hundreds of people trashing on their XB4's month after month with no issues at all.
Here in Europe we run on high grip astro and carpet all the time……..with no issues at all during an entire season of racing at the highest level with boosted 4.5T motor.
People need to:
  • Stop over-tightening screws for the diff housing (allows the diff housing/bevel gear to expand and affect gear mesh).
  • Stop overfilling their diffs (allows the diff housing/bevel gear to expand and affect gear mesh).
  • Stop over-tightening screws for the bulkhead cover using electric screw drivers (allows the diff bulkhead cover to expand and affect gear mesh).
  • Replace worn out bulkhead.
  • Replace both pinion and bevel gear if already stripped one of the gears.
  • Replace shot bearings.
  • Stop cranking their slipper down way too hard and instead set their slipper according to grip level (we run 0mm on the spring/loosest setting).
  • Stop using the 1/8th buggy method of cranking the throttle to get the car back on its wheels.
Just one of these things will affect gear life…….then add up several of them and you WILL have problems !
Material have been added by Xray to where the bearings sit in the bulkhead and to the bevel gear to prevent the gear mesh to be affected by the above points, BUT there is a limit to what you can do before the responsibility has to be on the end user to actually make sure everything is done correctly.
These cars are race vehicles and DO require some knowledge from the end user to perform at their best.
Follow these tips and you will have zero problems with gears wearing out prematurely
Enjoy your upgrade from the B44.3
Bent
Thanks and noted. Looking forward to the build.
Nat Maniac is offline
Old 11-10-2015, 07:09 AM
  #9242
seth556's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Nat Maniac
Hi everyone,
I've just purchased my first X-Ray, XB4 16 (long time associated user) and wanted to get some build advice in respect to the extending the life of the bevel gears.
At my local track (indoor carpet) historically the XRay users chew through bevel gears all too frequently, most recently someone went through 2 in one night with their new XB4 16. This has also been the achilles heel for the 15 models as well.
Given the cost associated with replacing these gears (and the DNFing)
1. Is there a mod to avoid or eliminate this issue?
2. Is this a common problem globally?
2. Why has X-Ray not addressed this issue in the 16 model?
Thanks for your assistance
It seems like everyone is building something wrong. The ring and pinion used to be composite and would still last quite a while, now they're steel and even beefier. Stripping them out, especially over and over, says that something else is majorly wrong. You shouldn't be having troubles stripping the gears. Bent seems to have the ultimate guide on properly building everything so nothing strips, I'd follow that to a t and you shouldn't have any issues.
The only thing I'd add, is be sure you don't forget to put the bottom two screws in the bulkhead. They're easy to forget but you will definitely have issues if you forgot to put them in.
seth556 is offline
Old 11-10-2015, 07:13 AM
  #9243
Slapjack's Avatar
Trader Rating: 19 (100%+)
I too my xb4 apart to clean it up and replace bearings and change diff fluid and when I put the rear end back together the suspension on the right side won't compress all the way. The shock compression stops about a 1/4" away from the full compressed position (see pic). The only thing I can think of is that I installed a new upright and idk if maybe it's not the right one? But idk if that upright is even the new one. I can't tell now.they both look the same ideas?
I've only had the buggy for a short time so idk if it was like this before I disassembled it or not. I don't think it was but can't say for sure.
Slapjack is offline
Old 11-10-2015, 07:33 AM
  #9244
seth556's Avatar
Are those the right driveshafts? They sit really far into the outdrive, especially for the middle suspension pin bushing.
seth556 is offline
Old 11-10-2015, 07:44 AM
  #9245
Slapjack's Avatar
I don't know if they are the right ones or not. Like I said I bought this roller from someone. I raced it a couple times and I am just now going through it. I am not home right now but if I remember right I think they said Hudy Spring Steel 68mm. Because originally that is what I thought is that it was bottoming out on the outdrive cup because I could feel it on the other side pushing when I compressed that one side.
Do you know what they are supposed to be? But why would one side compress properly and not the other if they are incorrect? They do go really far into the cup though.
Slapjack is offline
Old 11-10-2015, 07:58 AM
  #9246
seth556's Avatar
Since they are both so far in the outdrive, it could just be the camber is slightly different so that's causing one side to sit slightly farther in and hit. I run up travel spacers so the shock bottoms out before the driveshaft does, preventing them from binding up.
68 is the correct size for the rear driveshafts.
seth556 is offline
Old 11-10-2015, 08:00 AM
  #9247
BentKa's Avatar
Do you have a picture without the shocks compressed so we can see where the arms and driveshafts sit fully extended ?
Bent
BentKa is offline
Old 11-10-2015, 08:07 AM
  #9248
teeforb's Avatar
Trader Rating: 94 (100%+)
Pinion for a 7.5t motor?
teeforb is offline
Old 11-10-2015, 08:20 AM
  #9249
Slapjack's Avatar
Where would those spacers go? Do you have a pic or a page# from the manual? Or do you mean up travel spacers in the shock body itself? Do you have a link to what you are using for these? or a part number?
Bent
I don't right now. But I can post it around 6 tonight when I get home from work.
Slapjack is offline
Old 11-10-2015, 08:27 AM
  #9250
Anyone selling a center diff for the xb4 text me price 6144200732 thanks
justinchambers is offline
Old 11-10-2015, 08:58 AM
  #9251
Slapjack's Avatar
I was also wondering is it the norm to shim the diffs on the XB4? I didn't get this as a kit so I don't know if shims came in the kit or not but there are none in my gear boxes from when the previous owner built it. All my teknos had shims supplied to shim the diffs. My pinion and diff gear seem fine I am just wondering for future reference.
Slapjack is offline
Old 11-10-2015, 09:02 AM
  #9252
BentKa's Avatar
No shims in the gearbox as you can see from the manual.
The only shims used go inside the diff for the planetary and sattelite gears.
Bent
BentKa is offline
Old 11-10-2015, 10:15 AM
  #9253
BentKa's Avatar
Shims to adjust up travel goes on the outside of the shock and shims for setting down travel goes on the inside.
Included in the kit is plastic shims of 1mm, 2mm and 3mm (part #306219).
Depending on the position of the shocks, hinge pin inserts and camber links the number of shims required will vary.
Us the number of shims that keep the drive shaft from hitting the outdrive on full up and down travel.
This applies to both the front and rear shocks of course.
Bent
BentKa is offline
Old 11-10-2015, 10:38 AM
  #9254
BentKa's Avatar
21-22 depending on track size.
Bent
BentKa is offline
Old 11-10-2015, 11:36 AM
  #9255
Bentka,
I am thinking about purchasing the brass rear hanger set for my 16 XB4. Just wanted to get your input on how much they will benefit the buggy on loose bite track conditions.
Would you happen to know how many extra grams of weight they will add.
With your early advice to run my 16 XB4 with the motor in its spec kit position first over the rear position has me wondering about just adding the brass hangers for the extra weight.
As always Bentka I appreciate your help and thus sharing set up advise.
Best,
Norse
Norse is offline
