Like Tree248Likes
Xray XB4 thread
Old 01-29-2015, 12:39 PM
  #6871
kevinpratt823's Avatar
Originally Posted by Boz
Are your lap times better or is just a physiological thing now?
Great to hear about your eyes.
The eyes thing was 20 years ago, just giving an analogy of not realizing something is off until you try it the right way.
Lap times would be irrelevant, as there were other variables-the track was a brand new layout, still very wet(and almost frozen), all of our lap times dropped 3 seconds in a couple weeks, but I would venture to say yes, especially because it felt more consistent. I could actually punch it up the inside of the straight without rubbing the pipe. I also finished a couple spots higher in the A, and the top 2 drivers weren't even there the previous week.
It's really only a simple 3 minute change if you want to form your own opinion.
Or better yet, on the other end of the spectrum, take any other brand car with a setup you are already familiar and comfortable with, and mismatch the inserts to throw the toe off one full degree between sides and see if you notice it I'm guessing that would answer the question even better.
BTW, I'm guessing you meant psychological, not physiological, and surely there is a psychological component involved. If you drive a car that you know to be off you are going to notice it more(that doesn't mean it's not off), and when you have confidence in your setup it can also affect lap times in a positive way(that doesn't mean it's not a better setup).
kevinpratt823 is offline
Old 01-29-2015, 01:12 PM
  #6872
rchogfan's Avatar
Originally Posted by spu83
Have you try LHS I order mine from LHS took about 1 week.
My most local hobby shop is about 50 miles away and carries only traxxas and some cheaper stuff. I'm lucky to get the right shock fluid when I go in there. If I can't get it id be surprised to see him be able to he it. Thanks for the suggestion though.
rchogfan is offline
Old 01-29-2015, 01:56 PM
  #6873
skeasor's Avatar
Running a Novak Vulcan 7.5T motor with no endbell timing or boost on the ESC and running the 81T on the 2015 xb4, what pinion should I start with? I'm thinking a 20T. Does that sound about right?
Thanks!
skeasor is offline
Old 01-29-2015, 02:24 PM
  #6874
Iketruman's Avatar
Trader Rating: 14 (100%+)
Originally Posted by masin14
Local Hobby Shop...
Guess I over thought that one.
Iketruman is offline
Old 01-29-2015, 02:35 PM
  #6875
Thanks!
I ran a 18 and 19 with 81t spur, 6.5 w/10 deg on can, I forget what timing(maybe 20), and it was good for a tight track. You're probably in the ballpark to start with.
Old 01-29-2015, 02:38 PM
  #6876
skeasor's Avatar
Thanks!
skeasor is offline
Old 01-29-2015, 02:43 PM
  #6877
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by rchogfan
If anyone has a Center diff for sale I'm needing one asap.. rcamerica has lied to me 3 times about arrival date on one. Text me at 8708781302. Thank You. Needing it by next Wednesday.
When you called them did you give them your info to be put on the backorder list when they came in?
rcgod is offline
Old 01-29-2015, 02:48 PM
  #6878
FYI, if you can find the center diff adapter XRA364911 and gear XRA364978 then you can build a center diff out of a regular diff, you just need 4 screws to mount the gear, I think they were M3x5mm. Apparently the center diff outdrives are a different part number, but I bought these and a complete fr/rear diff last week and it worked fine. I got the last parts from Amain though.........
I got the info from a FB forum, I'm pretty sure he is a member here as well.
Old 01-29-2015, 03:12 PM
  #6879
Trader Rating: 30 (100%+)
Quick question for you guys...This is my first wheeler. Normally in 2wd buggy I run open cell foams in my front tires with closed cell in the rear. With 4wd I'm sure it is different. Are you guys running closed cell all around? Or using open celled foams in the front?
littleZEN is offline
Old 01-29-2015, 04:11 PM
  #6880
Closed cell all around.
Old 01-30-2015, 08:16 AM
  #6881
Trader Rating: 29 (100%+)
Default Xb4
Originally Posted by Raul Garcia
If anyone is looking for a center diff pm me. I have a brand new one and cant use it. It never had oil in it yet. PM me.
, raul its ed fr stamford, ill take it
blacktop20valve is offline
Old 01-30-2015, 02:35 PM
  #6882
blwaz23's Avatar
I run the aka closed cell foams.
blwaz23 is offline
Old 01-30-2015, 02:49 PM
  #6883
Jdubst13's Avatar
Wow I was just on Amain thinking about ordering this car but noticed all the bad reviews about the rear brace being off. After going through this thread looks like Xray refuses to admit there is a problem. It's hard for for to spend that kind of money and not get the support from a company in denial. I really wanted to get this car, heard it preformed great and I'm pretty much done with my 44.3. Hmmmm what to do.
Jdubst13 is offline
Old 01-30-2015, 02:56 PM
  #6884
suby723's Avatar
Trader Rating: 21 (100%+)
The 44.3 is a joke. I also had that car. Even with the toe off the car is fantastic! There will be a fix for the rear suspension holder. I wouldn't let that stop you from buying the car.
suby723 is offline
Old 01-30-2015, 03:06 PM
  #6885
Jdubst13's Avatar
Good to know, thanks. Just kinda sucks driving a car that you know something is off, gets in my head lol.
Jdubst13 is offline
