Like Tree248Likes
Xray XB4 thread
Old 05-31-2015, 12:32 PM
  #8371
Trader Rating: 22 (100%+)
Originally Posted by HulkNT1
I am trying to get the Ride Height but can only reach 21 in both rear and front with the basic spec I am running on clay track bumpy. The Basic setup said 18 for front and rear I have the XB4 2015 kit any idea what can I do to decrease to 18 or 19. I also see the buggy doe not have a droop screw.
My 2013 never worked well at the suggested ride height on a bumpy clay track. I ended up running more like 23f/22r to work well.
Troy Carter is offline
Old 05-31-2015, 12:39 PM
  #8372
MaricopaAgent's Avatar
Trader Rating: 28 (100%+)
Originally Posted by timannnn6
Have a question for you long term XB4 guys. I have an 2015 that I've broken two front axles in the last two times out on the track (one left and one right). Droop and up travel are set perfect. In fact, there is not one mark on the axles from the outdrives. EPA's are set perfect as well (no noise from servo at full lock). Both axles broke at the ball. Now I'm searching for replacements and none are available. Not driving related as I rarely hit anything.
Is this a normal problem for these buggies? At $25 a pop this will be an expensive buggy to run.
I twisted on off like you are describing. Only on my 15 when it was new. Sure was weird, as the 14 never had the issue.
check Ebay.. Normally some good new parts available.
MaricopaAgent is offline
Old 05-31-2015, 02:55 PM
  #8373
suby723's Avatar
Trader Rating: 21 (100%+)
Spec r shafts are the way to go.
http://www.egrracing.com/shop/index....oducts_id=5636
suby723 is offline
Old 05-31-2015, 03:52 PM
  #8374
timannnn6's Avatar
Trader Rating: 140 (100%+)
Spec-r's on order. Thanks guys.
timannnn6 is offline
Old 05-31-2015, 04:27 PM
  #8375
HulkNT1's Avatar
Originally Posted by suby723
What makes them so special??
HulkNT1 is offline
Old 05-31-2015, 05:36 PM
  #8376
suby723's Avatar
Increased reliability and slightly better cornering. Will you notice better lap times? Probably not but I broke a front shaft in the same place everyone else did with just hitting a pipe. You can't beat the spec r shafts IMO.
suby723 is offline
Old 05-31-2015, 08:02 PM
  #8377
Trader Rating: 43 (100%+)
Total agree. You really notice them I high speed sweeper as they almost have zero chatter.
Norse is offline
Old 06-03-2015, 05:33 AM
  #8378
HulkNT1's Avatar
Has anyone found good body for this car. Xray car is not easy to find body for there cars.
HulkNT1 is offline
Old 06-03-2015, 07:15 AM
  #8379
I haven't found one from another manufacturer that is designed for the xb4. There might be one that fits but it would take trial and error.
The xray one shouldn't be hard to find.
ATXPro4 is offline
Old 06-07-2015, 08:20 AM
  #8380
Hello all I want to introduce myself and say hello!
I have picked up the xb-4 '14 from a guy on here. I haven't got to mess with it yet but I will soon. I've just finished reading about 500 pages out of the 560 wow! Lots of good info here thanks.
iceman_bigb is offline
Old 06-07-2015, 12:11 PM
  #8381
rcgod's Avatar
Trader Rating: 33 (100%+)
Welcome to the club. Anything we can help you with let us know.
rcgod is offline
Old 06-07-2015, 03:25 PM
  #8382
Thanks and I'm here to help with what I can too
Old 06-07-2015, 04:19 PM
  #8383
Welcome to the club my friend.
Norse is offline
Old 06-08-2015, 07:41 AM
  #8384
SLOWINSLOWOUT's Avatar
Trader Rating: 20 (100%+)
I have one of these coming as well. I have been out of off road for quite some time, looking forward to running 4wd buggy again!(my last car would have been a Cat XL...)
Will be using it on a large out door track(35sec. laps) that is mixed clay hard pack, that can get blown out and dusty, and is fairly bumpy. Traction levels would be considered med to low.
Looking for some advice on the differences in battery layout and what each is intended for. Also some advice on chassis starting set up for the track I will be running on would be most helpful!!
Any and all tips and tricks, what works, what doesn't, I am all ears.
Cheers,
SLOWINSLOWOUT is offline
Old 06-08-2015, 07:51 AM
  #8385
rcgod's Avatar
Cheers,
The kit setup with 1 dot rear springs should be pretty good. I would run saddles and center diff with 100k to start. Also ride height 23mm. You can unscrew the shock ends a little to get more droop also, just make sure the driveshafts aren't binding in the outdrives under full extension and compression. The stock pistons are ok, a little smaller in diameter than they should be so I like the Schelle 1.1/1.5 pistons front and 1.1/1.6 in the rear with 37.5/30 oil depending on temp.
rcgod is offline
