Xray XB4 thread
#7021
Anyone selling a xb4 14 or 15?
#7022
I'm building my 2015 xb4 tonight and I'm either reading the manual wrong or something...What length drive shaft goes from the slipper to the front and rear when running a shorty? i have the 95mm in the rear and 85mm in the front and it's messed up haha. The manual says, 95mm (shorter) in the rear but 85mm (longer) in the front? How is 95mm shorter than 85mm? Any help is appreciated because I obviously have something messed up
#7023
#7024
#7026
Thanks....My front is binding badly. I have the diff completely out and any angle I put to the front drive shaft causes binding somewhere...If the drive shaft is level is spins freely but as soon as i connect it to the output drives of the slipper it binds. Cant figure it out.
edit: It's the actual drive shaft is binding. The cup that keeps the pin in is binding...hmmm
edit 2: fixed it...removed the grease, cleaned it up and regreased. odd. maybe not enough grease the first time
#7027
I wonder if I'm the first to have a broken steel pinion gear? I bought and installed the steel ring and pinion gears on my 14 XB4 as soon as they were released and ended up hearing the dreaded clicking sound tonight coming down the front straight . I was confused as I didn't believe I would have issues with the diffs after installing the steel gears but low and behold it happened . I'm running on hard pack dirt and my slipper is set at 7.54mm so I'm not running it too tight, the ring gear appears to be fine so I guess it's not so bad...good thing I have the composites as back up I guess
#7029
#7030
#7033
anyone grenade the front bearing center mount on a 14?
#7034
Yup . And a rear gear box inner one.
And far as metal ring n pinion it prob wouldnt hurt to open gear boxes and throw grease on tge gears from time to time even if not rebuilding. What kind of lube are you guys using on the metal gears. I just been using black grease but looking for something better.
