Xray XB4 thread
#6421
I'm going to make a really dumb suggestion and the only reason I am is because I had the same kind of problem with my B4.1. It seemed as though the axles were longer on my buggy than everyone else's, when I'd turn the rear wheels they'd bind in the outdrives. Make sure your pins are going through the drive shaft coupler the right way. Make sure the pin is going through the small hole and not the large hole.
In the pic I had the pin going through the larger hole (the red arrow) in the coupler rather than the smaller hole where it's supposed to go. Made a big difference.
#6422
Hey guys not sure how many people have had problems or wear on the car yet . But I am running my Xb4 15 at my local carpet track that has medium traction . Basically I am having a real issue with my outdrives and my outdrives on the slipper shaft both front and rear of the car . Not sure if any of you have had excessive wear on these parts but mine is getting pretty bad to the point that I'm almost second guessing this beautiful car because my wallet can not afford outdrives every couple weeks . This being said I have been staying on top and replacing my driveshaft pins .
if anyone can chime in on this that would be great
Thanks in advance
Thanks in advance
#6423
so they say this is for medium to high traction tracks. On the setup sheets on their site none say to use this. Thoughts?
#6424
R/C Tech Elite Member
Here’s the issue for me. What constitutes a high traction track? Without some kind of universal measurement that can be displayed accurately it really comes down to “try it and see if it works for you”. I’m sure what we in the northeast consider high traction the guys out in Cali would consider mid-bite. Unless the idea is high traction is considered carpet/astro then it really hard to know if this option would work for you at your track.
#6430
Yes, we have been running it on carpet with 1000K.
Great tuning aid for some tracks, but at the DHI Cup this weekend the feeling was too soft with the center diff, so the slipper was definitely quicker there.
A tuning aid I wouldn't want to be without, but not always the fastest option.....
#6431
For those of you running 500k and or 1 mill in the center diff, how are you getting this thick glop in there? lol
I just received the Hudy containers and they are so thick that I basically have to scoop them in. Warming didn't help much either.
I'm afraid that without the paste settling I would either get too much or too little in the diff.
#6432
#6433
#6434
https://www.youtube.com/watch?v=SmfInldgGsc#t=248
This guy has a syringe with the tip cut off that he uses to push the fluid into the diff.
#6435
I'm running on an indoor clay track. On a scale of 1 to 10, I'd say traction is a 7.5. We usually run a clay compound tire, like AKA Typos, Pro-Line Electron or JConcepts Dirt Webs. If the track is cold or starts to dust up a bit, I switch over to Super Soft Electrons or Dirt Webs. I have only tried 100K thus far. I really have no intentions of trying anything different at the moment because the car is the best its ever been and I don't feel like dealing with scooping super glue in and out of a diff
