Like Tree248Likes
Xray XB4 thread
Old 04-12-2014, 10:03 PM
  #4531
ferrarieeeee's Avatar
Anyone has experience with tekin rs gen2 w/ 8.5T?
ferrarieeeee is offline
Old 04-13-2014, 05:28 AM
  #4532
the rx8 will fit if you cut the fan cover off. the old rs pro is good. the new gen 2 rs is not for 4x4 but will work with a 10.5. the newest rsx is the one designed for 4x4 buggy.
i have an rs pro with an 8.0 motor and am very happy with it. motor will get to 160 after 8 minutes on a large track .esc is warm. no fans or holes cut in body
auto2 is offline
Old 04-13-2014, 08:21 AM
  #4533
rcgod's Avatar
Trader Rating: 33 (100%+)
If anyone is looking for a good medium to high bite setup try the Tyler Vik Reedy setup. Ran it last night on a high bite outdoor sugared track and my car has never felt that good.
rcgod is offline
Old 04-13-2014, 10:03 AM
  #4534
Customworksking's Avatar
Trader Rating: 74 (100%+)
I have a rs Pro and LRP 5.0 runs superb
Customworksking is offline
Old 04-13-2014, 01:09 PM
  #4535
Trader Rating: 342 (100%+)
Jus picked up 2013 v2 nib for 250! So I will try Tyler's set up...tx for tip...how crucial is weighing difs as u fill oil like addendum states? I jus filled 2 top of small spider gear shaft on both front n rear?
konasubs is offline
Old 04-13-2014, 02:42 PM
  #4536
rcgod's Avatar
That's how I do mine and they haven't leaked a drop.
rcgod is offline
Old 04-13-2014, 03:39 PM
  #4537
i have metal gears in mine and i put some oil in bottom and put one set of gears in then more oil in then other set fill it to top move gears around. then put the top gear in and rake excess oil off with hex driver then put the ring gear on top and tighten in cross pattern they never leak
evolution03 is offline
Old 04-13-2014, 05:19 PM
  #4538
tx guys...so on set up....I looked at petit and tylers set up for 2014....2013 set up all over the board. Is the box set up that bad? or good starting point for med high bite indoor clay med open track med smooth for 51 yr old dude with slower hands....lol...tx again...cant wait to run...
konasubs is offline
Old 04-13-2014, 06:36 PM
  #4539
rcgod's Avatar
I struggled with the stock setup. Car had way too much on power steering even on med bite. I've tried several of the setups on petit and with the help of one of the members here finally got the car to work for me. I'm 48 and don't have the fastest reflexes either. Biggest change are the springs. Stock setup is 2 dot front and rear. Once I went to 1 dot rear and 3 dot front the car started coming around. I actually run losi springs instead because my lhs had them in stock. Black front pink rear. So besides springs the only thing you'll need is the 1.4 rear sway bar.
rcgod is offline
Old 04-13-2014, 07:02 PM
  #4540
Errokk's Avatar
I run a mmp with a reedy sonic 6.5t with great results. Cheap and very smooth!
Errokk is offline
Old 04-13-2014, 07:12 PM
  #4541
Team Pink's Avatar
Trader Rating: 20 (100%+)
I have heard really good things about his Reedy setup, and from the sounds of it he doesn't change much track to track using that setup. Another setup that is really good that I use as a base setup everywhere is Martin Bayer 2013 Euros setup with the biggest difference being springs and shock oils most of the time. In the front I have found that I really liked the 3 dot and 4 dot spring over the 2 dot spring.
Team Pink is offline
Old 04-13-2014, 08:46 PM
  #4542
Trader Rating: 15 (100%+)
Losi pink = 2.3lbs, pretty much the same as the stock 2 dot rear. If you use the standard TLR springs, you want to get down to 2.0lbs/1 dot, which is a yellow spring. If you have the TLR LF springs, try white = 2.02lbs.
TV's set up using 3dot/TLR Black = 4.11lbs - pretty stiff! But hey, it works. I notice he uses the stock 3 hole pistons and 40wt TLR oil, which I think is like an AE 37.5wt/450cst? 27.5wt TLR is some where around 30wt AE or about a 350cst.
I'm planning to run his set up as well, but using Avid 1.5+1.1 in front with CORE 450cst and TLR black, Avid 1.6+1.1 with CORE 350cst & TLR LF White.
Is it summer yet?
HeavyD99 is offline
Old 04-14-2014, 07:05 AM
  #4543
"27.5wt TLR is some where around 30wt AE or about a 350cst."
Did you mean to say TLR 27.5 wt is close to AE 25 wt?
I've seen a lot of conflicting info on different brand shock oil comparison, not sure what to think other than to stick with one brand and find what wt works for you....
kineteks is online now
Old 04-14-2014, 07:20 AM
  #4544
so are you running the pinks and blacks that would fit on a xxx series or the tlr22 series? I happen to have both....tx again for input...
konasubs is offline
Old 04-14-2014, 11:53 AM
  #4545
Default Saw my 1st XB4 on a track last weekend!
Saw the Xray XB4 4w for the first time in person on a track, all I can say is WOW! I was at the Jconcepts race at TRCR last weekend.
Tyler Vik driving the XB4- Fast driver and great car. Tyler was the only Xray that I saw at the race although Tyler said he saw 1 more X-ray there. Tyler laid the smack down on the Associated team and Team Losi and every other sponsored driver in the NW in 4wd mod buggy with the TQ. Tyler shouda won the overall but :
A1 Tyler made a couple of mistakes when he was leading
A2 Tyler led the race from bell to bell!!!!!
A3 Tyler led the race almost bell to bell but was hit some say hacked right near the end of the race....
XB4 2wd-Tyler was BQ. TYler led the B main race from started to almost the finish, but was hit in the rear and taken out with a few seconds left in the race. Xray should have been in the A main also.
I bought an XB4 on ebay last Friday as I was sitting at the track waiting for my battery to charge, then a few minutes later my RC buddy tells me there is an Xray driver there at the race .....Karma lol
What a great weekend at TRCR......soooooo fun, Great race.
KyoshoSC is offline
