Xray XB4 thread
#1774
focus on oils first. heavier to slow down the springs reaction or lighter to allow the spring to work more. and try different springs. BUT Depending on the way the bumps are you might just leave it alone. don't dial yourself out of 90% of the track to be dialed for 10%.
#1776
+1... I always install mine in the same direction as well. I always want the turnbuckle to do the same thing on both sides of car when I am looking at it from either end.
#1779
focus on oils first. heavier to slow down the springs reaction or lighter to allow the springth to work more. and try different springs. BUT Depending on the way the bumps are you might just leave it alone. don't dial yourself out of 90% of the track to be dialed for 10%.
#1781
I fully understand how the use of the bushings applies to changes in the car which is why I asked for an explanation. To that point the answer has still not been given. Toe change ? Track width change ? Rear only ?
It would help to use complete and correct terminology.
#1782
I'm using the factory terminology directly from the manual, it refers to them as FF FR RF RR . So in fact the term rear as I said applies to 3 of the 4 suspension holders. Using those terms clearly indicates which one where the eccentric bushings are changed.
If you understand how the bushings work, you would understand that adding .5 to the outsides of both the front and rear of the rear gearbox would give you a greater track width. Putting the same .5 bushings to the inside would give you a narrower track width.
Simple enough?
#1785
and ride height closer to 18 or 19 is probably going to help too.
good luck
