Tekno RC EB48 Thread >
Like Tree2Likes
Old 05-18-2015 | 08:19 PM
  #14716
Mizchief's Avatar
Originally Posted by justinco
Good advice from the others already. I built mine using the process in the following video, never had any leaks or issues. Keep in mind this was on my original SCT410 (same process I used in my EB48).
+ YouTube Video
https://www.youtube.com/watch?v=n0B46KBZKFw
Good tips I got from this were to use a really light oil to help clean out the old thick stuff, and to fill the diffs half way before putting the cross gears in.
Mizchief is offline
Old 05-19-2015 | 07:03 AM
  #14717
wittyname's Avatar
Customss , I had a big stability problem as well with my car. Mark Unrath hooked me up with a great set up for my track ( Great they actually run there ) . He has shared it here before so I don't think he would mind me re posting it . The pistons , oil , springs , and hexes all made my car a different animal.
wittyname is offline
Old 05-19-2015 | 04:10 PM
  #14718
thanks i will give it a try
customss is offline
Old 05-19-2015 | 05:32 PM
  #14719
I just picked up a 48.2 the other day. Is there any changes I should make right away for example the shock springs and pistons like i did with the 410? Thanks
Bracer11 is offline
Old 05-19-2015 | 05:55 PM
  #14720
Originally Posted by jmkalt
I have a 2 year old, original EB48, but updated with all the lightweight drivetrain components and newer arms, etc. I'm presently running a composite setup taken from a variety of drivers for similar tracks (it's basically an average of their setups). Weird, I know.
This buggy has good "ground game" but suffers in the jumping department. It tends to jump "up" where other buggies have a flatter trajectory. It also seems less stable than other cars when the face of the jump is not perfect, causing it to be squirrely in the air.
Is this something that is inherent to the EB48 itself, and merely something I have to live with as long as I run this car, or is there something generic I could try to change in my setup to alleviate this?
There are at least two ways to hit a jump. I like to run up fast and let off near the bottom, this will get you a flatter faster jump... if you pedal it before the jump and then goose it up the face you will go higher and just as far, but is a slower line.
slimgravy is offline
Old 05-19-2015 | 06:00 PM
  #14721
Pistons are really the only thing from the box that id change...
Altho I did pick up the 2 piece mount from pete at fierce rc... wow that was worth every penny!!!
Old 05-20-2015 | 11:06 PM
  #14722
vandalzzz's Avatar
Can you please measure camber link' lenght with such 2/1.5 F/R camber settings and endpoint locations?
vandalzzz is offline
Old 05-21-2015 | 06:28 AM
  #14723
wittyname's Avatar
I use a gauge . It will be days before I have the car and calipers in the same place . Someone else may be able to do it quicker
Old 05-23-2015 | 02:24 AM
  #14724
MOE's Avatar
MOE
Everyone must be busy racing... just bringing this back to the front.
MOE is offline
Old 05-24-2015 | 05:54 PM
  #14725
Default Dog Bone pin replacement
I need some info on replacing the pins in the dog bones. I have the Hudy pin drive tool which has always served me well. Today I tried to replace the dog bone pin on the center-rear shorty dog bone on my EB48.2. I used a Mugen pin (3mm x 12.8) and as you can see in the picture it split the end of the bone. Do these dog bones take pins smaller than 3mm? Or are you supposed to simply replace the whole unit instead of just the pins? The pins in the rear drive shafts should be replaced as well since they've become very flat, but I don't want to attempt it if the pins aren't meant to be replaced. I've probably replaced close to 100 pins in my previous Mugen, XRay and Serpent buggies and truggies and never had an issue until today. This is the first attempt at replacing pins in a Tekno vehicle.
Wease is offline
Old 05-24-2015 | 06:00 PM
  #14726
FastPete's Avatar
Compare with calipers, I bet the Tekno ones might be a few tenths smaller.
FastPete is offline
Old 05-24-2015 | 06:01 PM
  #14727
I have no first hand experience but remember guys saying that its hit or miss with these axles. Some Will take a pin some won't.
Dragonfueled is offline
Old 05-24-2015 | 06:19 PM
  #14728
I just compared the two and both mic'd out at 2.97mm. The rear drive shaft/cva pins need replaced one way or another because they are really flattened. So I gave them a try and had no issues replacing the pins in the rear dog bones. Not sure why that center-rear didn't go as well, but lesson learned there.
Wease is offline
Old 05-24-2015 | 06:28 PM
  #14729
I replaced 9-11 of them a couple of weekends back. The only one that had issues was the rear shaft of the EB48, both ends split, but I had some SERIOUS wear on that (probably 30% of the pin was gone). That looks like the same one you had issues with. I'm wondering if it's the part or somehow the stress we exert on that small piece? Right off of the center drive shaft on only 1", between diff's, imagine the torque that thing gets hit with. A recommendation I read was to heat up the material first.
So to summarize, I would say yes it's still a great idea to try that first before just pitching it and buying a new one as your chances for success are decently high. I will give the heat trick a try next time as well.
RokleM is offline
Old 05-24-2015 | 08:52 PM
  #14730
I have just got 2nd hand EB48.2 and it has CSI shock on it
But I got tolled csi don't do shocks for this car
So what would that be off
Brenden is offline
