Tekno RC EB48 Thread >
Like Tree2Likes
Old 08-08-2013 | 04:43 PM
  #8356
That's pretty smart.. just giving a slight angle would allow the bearing to be raised a decent amount.
I wonder if this would help the high center diff temps some of you guys are seeing.
some guy is offline
Old 08-08-2013 | 05:02 PM
  #8357
I bet the rear driveshaft will last a lot longer.
Mullet1 is offline
Old 08-08-2013 | 05:19 PM
  #8358
Genebaby's Avatar
Makes total sense.
Genebaby is offline
Old 08-08-2013 | 05:51 PM
  #8359
samuelsonmark71's Avatar
Would running two 3800 shorties wired as 4s (50c) be enough?
samuelsonmark71 is offline
Old 08-08-2013 | 06:03 PM
  #8360
Genebaby's Avatar
Depends on your ESC and motor.
Genebaby is offline
Old 08-08-2013 | 06:06 PM
  #8361
Originally Posted by Mullet1
here is the new gearbox, straight cut input gear and ring gear installed. You can clearly see the difference as there is almost no angle now.
Nice! Looks like I'll have to pick one up.
MX304 is offline
Old 08-08-2013 | 06:21 PM
  #8362
Rx8 gen2 and 1900 Tekin motor. For 10 min mains, I think the shorties will do well
Old 08-08-2013 | 06:24 PM
  #8363
A question for those using the Fioroni pistons. How far in oil weight should you drop? I'm currently using 700cst front and 35 Losi rear.
Thanks.
w_dupree is offline
Old 08-08-2013 | 06:56 PM
  #8364
ChrisAttebery's Avatar
They should be OK. I ran two 2s4200 shorties in series for a while. Just make sure you set your LVC cutoff to 7.0V or higher. Over draining a lipo is the fastest way to ruin it.
BTW: With a 3800 pack you'll be lucky to get 10 minutes. With the same system I was pulling 400mA/minute the last time I checked.
ChrisAttebery is offline
Old 08-08-2013 | 07:14 PM
  #8365
Thanks.
i run 35 losi front and rear
skinnyricky is offline
Old 08-08-2013 | 07:42 PM
  #8366
Ok thanks, what springs are you using? I'm using k orange front and k yellow rears, I think I'll try the stock springs.
w_dupree is offline
Old 08-08-2013 | 08:05 PM
  #8367
Originally Posted by teknorc
Here's Austin's A1 win at the ROAR nats this past weekend. It was a good race. Austin finished up 3rd in all 3 classes.
http://www.youtube.com/watch?feature...&v=Xvv7724N9mA
Is Austin going to post his setup sheet for this race ? It would be greatly appreciated
rythby is offline
  #8368
What kind of surface do you run on?
JASF4I is offline
Old 08-08-2013 | 08:15 PM
  #8369
i run kyosho gray fronts and kyosho green rears. i also used stk fronts and tekno red rears with gud results, didnt like the stk rears with the losi 35 wt.
the trac i run the most is a med/large fairly rough low/med bite and a couple of large jumps with landings.
Old 08-08-2013 | 08:19 PM
  #8370
To run the new gearbox do we have to use the straight cut ring gear or will the older one work just as well?
McGuire is offline
