Tekno RC EB48 Thread >
Like Tree2Likes
Old 08-08-2013 | 08:56 PM
  #8371
teknorc's Avatar
Originally Posted by Racer591
To run the new gearbox do we have to use the straight cut ring gear or will the older one work just as well?
100% compatible with the old gears. You will need the larger bearing though (TKRBB05134).
teknorc is offline
Old 08-08-2013 | 09:20 PM
  #8372
Rockthecatbox21's Avatar
Sweet. Do you guys know how long it usually takes amain to get new parts from you guys in stock? Either way i'll be picking up a couple with some bearings.
Rockthecatbox21 is offline
Old 08-08-2013 | 09:38 PM
  #8373
teknorc's Avatar
Probably a week or two. They need to take pictures and get everything in the system. Same with Tower, Stormer and others, might take a week or two.
teknorc is offline
Old 08-09-2013 | 03:42 AM
  #8374
So these are selling on the tekno site right now? I don't want to build my kit without it..
some guy is offline
Old 08-09-2013 | 05:56 AM
  #8375
vfrninja's Avatar
Default Tekno
Dear Tekno,
You guys are awesome.
Sincerely,
Luke Franzen
vfrninja is offline
Old 08-09-2013 | 05:59 AM
  #8376
Graham11's Avatar
Anyone see the new Losi 8ight-E 3.0 coming out in a few weeks? Looks like they just copied the EB48.
Graham11 is offline
Old 08-09-2013 | 06:33 AM
  #8377
bcjoldbq's Avatar
Definitely a departure from the wide nitro chassis w/ conversion, a electric-only design. Kind of speaks to the increasing popularity of E-1/8 buggies.
But Tekno was 1st, who cares who is 2nd.
The electronics layout is switched around a bit from the EB48 though with the battery and motor farther back. And ESC on the left instead of the right side.
bcjoldbq is offline
Old 08-09-2013 | 06:40 AM
  #8378
I think that now that motor, ESC and battery technology have caught/surpassed the performance level of nitro it was only a matter of time before "E" specific kits were developed..
Also I don't know if I would call the Losi 8ight-E 3.0 a copy of the EB-48. Yes they made it narrower but that is inevitable when designing a "E" specific buggy. However when you look at drive line, motor position and parts it really doesn't compare to a EB-48 at all. I would say techno is design with no compromises to performance and uses high precision parts. The Losi while nice has a "compromise" design and if the parts are typical of Losi stuff will have parts with not has high of a precision level.
merkyworks is offline
Old 08-09-2013 | 07:22 AM
  #8379
Cain's Avatar
Tech Legend
I will be doing full teardowns and servicing of my EB48 and SCT410 this weekend. Trying to find out why the front end of the EB48 let going and just spins now.
My question is this, and I appologize before hand if this is an easy answer type one, but for the whole new gears, etc. If I need gears for my front end, do I need to do all the gears in the vehicle (rear) or can I go new up front, old / current in the rear?
Cain is offline
Old 08-09-2013 | 07:46 AM
  #8380
Cain, you can do just the front or rear at a time. The key is that you have to change the ring and pinion at the same time.
MattDub is offline
Old 08-09-2013 | 07:50 AM
  #8381
If the front just spins free, it's probably not your ring and pinion gears. The first place I would look is the set screw that holds the dog bone coupler to the front pinion gear. I have had mine back out a couple of times.
MX304 is offline
Old 08-09-2013 | 07:56 AM
  #8382
Cain's Avatar
Tech Legend
thanks. I am crossing fingers that's its just that lol. Just been too darn busy to really sit down and see what is what.
Cain is offline
Old 08-09-2013 | 09:17 AM
  #8383
GrimmReaper's Avatar
I've done some more testing with the CSI Blue V-Ports and I'm getting better results. Feels great on the bench. 12" drop, no bottoming out, but it feels really soft.
25wt AE Front with Yellow Springs / 20wt AE Rear with Orange Springs. Buggy is really good in the bumps and jumps. It also rebounds very quickly, faster than the my 8 X 1.3's with the same pack feeling.
I'm going to test it with a one rate drop in springs front and rear this weekend. The buggy has never felt so good.
GrimmReaper is offline
Old 08-09-2013 | 10:26 AM
  #8384
I have been working on those pistons for a while now. Finally got fed up and took the tekno shocks off the car entirely. Replaced them with mugen shocks. Tore down the tekno shocks and the guides inside are all screwed up. Kind of shocking. The car is only about two months old and I don't run that often. I ended up with 27 in the front and 25 in the back. kyosho lt blue in front and orange in back. Not too bad . once I order the new parts i'll try again but for now I am sticking with mugen shocks.
rythby is offline
Old 08-09-2013 | 10:55 AM
  #8385
I don't think you're the first one to have issues with the shock guides. I think they may have made a revision to the old shock guides too.
I did try the 27F/25R and for me it was too stiff. It didn't feel terible, but I noticed that I couldn't carry nearly as much speed into a jump as it was throwing me way to high in the air, and carrying my car too far off of the landings. As soon as I softed it up a bit, the car got tons better in the bumps, and I could hit jumps a lot harder.
