Tekno RC EB48 Thread
#6856
Paul Rush
#6857
http://www.vpprousa.com/rc-parts-acc...category_id=22
Paul Rush
#6860
#6861
#6863
Other arms will fit. As a matter of fact I love the Racer's Edge pro horns. I just shimmed the ackerman end up with a large (3mm) washer and a longer screw and used some loctite on the arm/screw. No issues, They work great. I can post a pic of my setup if need be so others see/understand it
#6864
This one works well. I have it on My SC410 and am thinking about getting one for my EB48. I like it better than the Hot Bodies horn.
http://www.amainhobbies.com/product_...orn-25T-ProTek
Its offset down a little rather than up alot like the HB horn. You just mount the link to the top of this and it is almost perfectly flat.
#6865
EDIT: Woops - disregard. I read the poster who replied to yours who said it was Hitec. 24T is Hitec, 23 is JR.
#6866
Thanks Grim ! Wanted to do something different this time from my normal blue/white schemes ....... They look a little more raspberry in person than the pink the camera makes them look . There is also a florescent grieen outline on the flames of the buggy that the camera doesn't pick up .....
#6867
I'm really happy to hear that you like it so much! It's great to get feedback like that. The car was too unstable for me when I first got it, so I just kept working on it until I liked it.
I think the Kyosho springs will help with the steering. If not, let me know and I'll do what I can. I tried 3K in the rear diff and didn't like it. The car constantly wanted to diff out and over rotate coming out of the corners. The diffs in this car are very small, so you have to run thicker oil than normal. You could try moving the front shocks in one hole on the tower.
I have some mugen rear 1.5/8.75 springs don't know what the n/mm is think these may work?
http://www.amainhobbies.com/product_...Soft-15-875T-2
B
#6868
What does the stock shock oil viscosities #450 and #350 correspond to in other viscosity measurement systems? cP? cSt? Wt?
Normally I use Ultimate Racings shock oils. What will be good replacements for the stock shock oils?
/Birger
/Birger
#6869
Now I think I understand y guys are going to the heavier spring in the rear. Went to RCE's outdoor for the first time and they have a nice big track, sweet driver's stand and a lot of great racer's. I had the new vport CSI's w/recomended 27.5/20 and stock springs that felt good on the bench but after a few laps in the 95*heat I bumped it up to 35/30, front was $ and rear I had nice ride hight but slow rebound like the spring wasn't heavy enough or oil was too thick. There was a couple sections of track where I had chassis slap so bad that it would send me a$$ ova into the next lane. 1 spot it was every other lap, There was a 180 into a sweet step up that had a nice downside to a double into a tight 90* lefthander, I was having better luck over shooting the double to flat "w/my 4x4sc" because the landing was kinda tall and steep so u would case it real easy. When I would try this w/the buggy, the chassis would slap and bounce right ova on the wing or I'd case it and do the same thing! So, New CSI blue's soak up bumps great but I think I need the stiffer r spring like most of u run... A guy at the track said if the front is too stiff it will slap the rear but the front feels good to me. Any thought's?
BTW, I turned down my .15 jr 9100t servo speed to 65% on spektrum DX3R pro, stiffened up the rear roll by dropping the link on the tower, added a 2.6 sway bar, also have the 2.4 in the front, cut the bat tray so lipo slides back to the motor mount w/2 foam pads in front. The EB dug hard and stayed planted in the corners. Wondering if I might have to change it back when I use a stiffer rear spring tho..
#6870
2Likes
