RC10T4.1 Thread.
#316
Check out the awesome aerial shots one of our local dirt oval club members took of the new track site. They were flying overhead when we were working on Sunday. You can get an idea of how big the new off road track will be when you compare it to the 10ft by 6ft sections of stand we have laying in front of it. Check out the ridiculously bad a$$ banked dirt oval they built right next to it. You can already see the groove forming from the air and they've only been racing 3 weeks at the new site.
http://www.rctech.net/forum/florida-...peedway-2.html
#317
Moderator
Is there a mod for a +8 chassis for the t4? I know I saw one for an AE 2wd but it could have been the buggy. How does the t4.1 compare to the 22T in durability and handling? I am thinking of getting a used t4.1 to race. Any thing I should know? Any recent worlds parts or anything? Is the factory team much better than the rtr?
#319
If you want to try bladders in your Associated shocks, you can use the ones in the VCS2 upgrade kit, but don't use those caps....use the bleeder caps, but don't put the screw in. When built properly, the bladder won't let oil by, and by leaving the bleeder screw out, the hole in the cap will relieve the pressure as the shock is compressed.
I've never noticed a performance advantage or disadvantage running the shocks this way, they're just different.
#320
#321
I re-bled one of the rears last night for a test. Initially I bled them similarly to the emulsion style and was happy with the results. Last night I put the shaft at ride height and then installed the bladder and cap. With this technique the shaft would lock ~1/4" prior to full compression. I think that the bladder is impacting the cap at that point. So, tonight I'm going to see if I can test the extension with a clear cap to see how far the bladder is actually stretching with my current configuration.
#322
Nice wheels and tires. what are they?
Figured id post some pictures of my T4. I havent had it long. Its a little different than most of the talk in here because I bought mine with intentions of finding a good basher that also handled well. I have been running stampede's for years and decided i wanted to try a stadium truck after my last stampede. I bought this T4 and love it so far. I have broken a couple small things, but i feel after some little upgrades it will be a really strong truck. The stampede is more durable, but the T4 out handles it by a lot and is much easier to control with brushless power. Not to mention the transmission is whisper quiet and smooth as glass
I also just bought a T4.1 and had plans to sell it, but my wife says she likes it better than her stampede she runs, so its staying too. No pictures of it yet, but here is mine:
What wheels and tires are those? and what did you do to make them fit?
#323
#324
Trader Rating: 123 (100%+)
If your using a bladder, and set your shocks via the same method as I outlined in a previous post - you may actually inccur negative pressure in your shock. --- Compressing the shock to "bleed" it pushes out the air, then you tighten down the screw creating a vacuum. You will know you did this when you extend the shock to full length, let go, and it sucks back into the shock body a few mm's.
Leaving the screw out, you create a vent chamber. air in, air out. the bladder will stop leakage, the shock will act slightly different (for me it seems like its "bumpy")
I have been cutting out bladders for as long as I can remember... They just feel the smoothest and most reactive.
#326
I set it to answer your question, and so many more...
#327
Click the Best link a racer could ever want <<<---
#328
#329
So tonight I removed the shock cap from the right rear, compressed the shock, then installed the bladder and let it extend fully under spring pressure. If I had my calipers handy I would have measured the displacement. :-/ It looks like maybe 3/16 deflection, which is less than I thought it would be. The following pics are of the bladder with the shock under full extension.
#330
after hearing that you guys are only getting 1-2mm of rebound after building your shocks, I went ahead and attempted to redo mine to achieve the same result. 2 hours, some cussing, and 4 beers and I still can't get less than 4mm. I'm going to pick up the bleeder caps tonight and see if that helps.
Has anyone been able to get 1-2mm of rebound using the standard (non-bleeder) shock caps? If so, HOW?? I've followed directions to the T, and even let the shocks sit overnight before I bled them.
