RC10T4.1 Thread.
#333
It's the Proline Bulldog body. Seems to be the most popular body at our local track, so since I needed a body, I figured I'd go with that.
I lost another Tekin this week so the truck probably won't see the track until Tuesday. Really anxious to wheel a stadium truck again!
#335
after hearing that you guys are only getting 1-2mm of rebound after building your shocks, I went ahead and attempted to redo mine to achieve the same result. 2 hours, some cussing, and 4 beers and I still can't get less than 4mm. I'm going to pick up the bleeder caps tonight and see if that helps.
Has anyone been able to get 1-2mm of rebound using the standard (non-bleeder) shock caps? If so, HOW?? I've followed directions to the T, and even let the shocks sit overnight before I bled them.
#336
Has anyone tried this on there T-4? A friend told me about this and said it works great on the B4,
#337
#341
Update on my rebound issues. Bought the bleeder caps and WoW! Sooo much easier to work with. Managed 1-2mm of rebound on my first try.
I also cleaned the grease out of the diff and replaced it with 3 parts 5000wt and 1 part 2000wt. Gives me an avg of 4250wt. Diff feels quite a bit tighter but not overly tight. Anxious to give it a try.
Question, after putting the trans back together, I noticed it had some resistance, obviously this shouldn't be there. What should I check first?
#342
Trader Rating: 123 (100%+)
#343
any one have cav crcrc set up?
or something more up to date then what on ae site?
and what big bore springs have you guys been running
#345
Just ordered a cheap exi servo from hobbypartz.com to replace the craptastic RTR servo that comes with the truck. I'm willing to take a $15 risk that this may be a great servo before I plunk down the money on a name brand one. I know I love my cheap Gens Ace batteries, it's worth another shot on a servo. Stay tuned
