Serpent 811E Buggy Thread
#4577
I am running basically the stock set up on my buggy. I have the v1 rear end but v2 gears. My diffs are 10 20 7 f c r. I am running .5 degree less to in in the rear and 2 degrees of toe out up front. I have the #2 ackerman bar also. Shocks have the 8 hole conical pistons, 500 front, 400 rear with stock springs. I added 1 mm of rear droop and it seemed to help the problem some. Should I add more?
This is my set up in regards to my problem with wandering/ spinning out under breaking.
#4578
I always ran more down travel front and rear in the electric car than I did on the nitro car. It must be the heavier weight of the electric car. Whenever I tried the same long down travel on the gas car it wasn't as good.
#4580
Whats a good motor/esc setup, with 4s shorty packs, for a small, tight indoor track?
http://www.youtube.com/watch?v=BW15qzFnviE
Can a nice 4WD SCT motor/esc fit appropriately and help save weight?
http://www.amainhobbies.com/product_...-w-EZ-Link-65T
#4581
Am I the only one who feels that this e-buggy is almost too quiet with a composite spur gear? Don't get me wrong, I absolutely love the fact that the drivetrain is so smooth that its silent. But It feels weird not to be able to hear it at all over the other e buggies. I like to be able to have some audible feedback from my vehicles. I'm considering going back to the metal spur gear just so I can hear my buggy.
#4582
https://drive.google.com/file/d/0B03...WhFNUk/preview
#4583
If anybody with experience/knowledge/opinion wants to weigh in in regards to shorty packs vs. regular, I would like to know your thoughts. This is in addition to what I have already read in this thread.
10min mains. Large, outdoor, blown out clay track. I am primarily concerned with performance of the buggy.
I just pulled the trigger on a kit, so I have no experience with it yet.
#4584
#4585
Starting to lean slightly toward shorties
#4586
So what has been the trick to get these to turn better? Im running a tight, medium bite, indoor track. Im still fighting a little bit of a push and its not quite turning the way i would like it to.
#4589
#4590
On or off power? Most of the suggestions I am seeing will help with off power entry turn in. The ackerman adjusts should help across the board though. Lighter rear diff oil may also help with rear end rotation if it is on-power turning.
5Likes
