Serpent 811E Buggy Thread >
Like Tree5Likes
Old 11-17-2013 | 05:49 PM
  #4336
Willing to separate. And how much?
Gvm23 is offline
Old 11-17-2013 | 05:58 PM
  #4337
RCmayor's Avatar
http://www.rctech.net/forum/r-c-item...rogrammer.html
Check my for sale thread. if you have a serpent car I will send a set of carbon battery straps also.
RCmayor is offline
Old 11-17-2013 | 06:07 PM
  #4338
Yes I've seen your ad, are you willing to separate? I already have the carbon straps.
Gvm23 is offline
Old 11-17-2013 | 06:33 PM
  #4339
RCmayor's Avatar
No that was just a bonus if you needed some.
RCmayor is offline
Old 11-17-2013 | 06:54 PM
  #4340
rdeppen's Avatar
Originally Posted by Gvm23
Might has the lightened battery tray. And will be running pretty heavy batteries unless I buy some new ones so it won't be a lightweight but both tracks I run on are small.
What kind of run time can you get on shortys? All I have right now are 6500 and 7200 that I can run I'm my sct410.
I use 2 4600 pro match shortys. I have no problem running 10 minute mains.
I use about 3800 mah's over that period with no more then 2-3 practice laps.
rdeppen is offline
Old 11-17-2013 | 06:55 PM
  #4341
Nice to know thanks.
Gvm23 is offline
Old 11-17-2013 | 09:06 PM
  #4342
Nice. What size track and motor are you running.
Nexus is offline
Old 11-18-2013 | 11:03 AM
  #4343
dtr's Avatar
dtr
I run a t8i in my serpent. I'd never go back to a big motor but I also run a very light setup. Car just works better with the shorty packs small ESC and the little Tekin.
How much does it weigh?
dtr is offline
Old 11-19-2013 | 02:22 PM
  #4344
will this motor fit in the serpent ETRUGGY (not buggy) (ie, nitro truggy converted using Serpent conversion kit)?
T8 GEN2 Specifications:
KV Rating: 2000
Shaft Dimensions: 19 x 5mm w/flat
Motor Diameter: 40mm (42mm including fins)
Motor Length: 77mm
flyrod is offline
Old 11-19-2013 | 04:19 PM
  #4345
in step A11 - does the transmission grease go on just the diff gear? or also on the diff outdrives? - thx!
flyrod is offline
Old 11-19-2013 | 05:48 PM
  #4346
Its meant for the gear. Just for break in. grease wouldve been applied(mainly to fill the groove) to the outdrive before it was put into the diff case/ ring gear.
jsorwell is offline
Old 11-20-2013 | 05:09 AM
  #4347
just to be clear, you are saying NO do not grease the diff outerdrive - correct?
flyrod is offline
Old 11-20-2013 | 05:46 AM
  #4348
rdeppen's Avatar
My buggy weighs in right at 3300 grams. Only lightweight parts I don't have are the aluminum outdrives.
I run the Tekin 1950 T8i motor and our track 165x95
rdeppen is offline
Old 11-20-2013 | 12:57 PM
  #4349
4ptss's Avatar
KV Rating: 2000
Motor Length: 77mm
Yes it will.
4ptss is offline
Old 11-20-2013 | 01:08 PM
  #4350
thx Matt
flyrod is offline
