Serpent 811E Buggy Thread >
Like Tree5Likes
Old 05-08-2013 | 08:38 AM
  #3721
well i now have the CS black and blue pistons. Think i am going to try the blacks first. what is a good starting point with the stock 2.0 springs? I am not sure if i am going to be running indoor or outdoor this week is the only thing.
Was thinking of starting 40wt front and 35 rear AE oil with the blacks.
DsWright is offline
Old 05-09-2013 | 03:40 AM
  #3722
maddog9's Avatar
Originally Posted by H0LESH0T
Cobra E-Buggy Ready To Race 1/8 ElectricPowered The RTR version of the successfull high end Serpent 1/8 Cobra Buggy. Complete with DragonRC 2.4 radio, metal-gear servo, brushless motor, waterproof speedo, prepainted-precut body and premounted offroadtyres 4-wheel-drive, 3 geardiffs, 16mm bigbore shocks, aluminium shocktowers and chassis, easy radiobox, sideguards, low batteryboxes, rear wing. Fully upgradable with parts and options from the high end race-version. This super durable Buggy chassis allows a great entry in the racing scene, at a lower cost, and will make you finish your races! Cobra E-Buggy RTR
Looks nice, be nice to find out the price compaired with the RC8 RTR
http://www.amainhobbies.com/product_...adio-Motor-ESC
maddog9 is offline
Old 05-09-2013 | 04:35 AM
  #3723
Ok, so am I hearing this right? I can just stuff the 2.4 ghz antenna wire in the receiver box and don't need the plastic antenna tube? I used a reamer and was able to make it fit.
Also, my stock kit came with 300 wt silicon shock oil. Seems a bit heavy based on what I am use to with my other cars??
Thanks so much for all the help guys.
gocoogs is offline
Old 05-09-2013 | 04:42 AM
  #3724
Maxxingout's Avatar
With the blacks, those oil weights will be to heavy. I'd start out with 32.5 F & 27.5 R, with blue front springs & yellow rears.
Maxxingout is offline
Old 05-09-2013 | 04:44 AM
  #3725
Yea my antenna wire is tied up in the box and no issues, DS id say go 40-30 for a starting point.. I'm not sure what springs are stock but i run white or yellow on rear with 2.7 bar and blue or purple on front with 2.3 bar.... front 2 UP and 2 down then on rear 6 with 5 out on lr bracket
Racermac73 is offline
Old 05-09-2013 | 04:55 AM
  #3726
What do you mean by... "front 2 UP and 2 down then on rear 6 with 5 out on lr bracket" ??
gocoogs is offline
Old 05-09-2013 | 09:21 AM
  #3727
The black plastic inserts.... front nearest the bumper a 2 with the hole towards the top on backside of front a 2 with hole towards the bottom, the front side of rear a 6 (hole is in middle so don't matter how it's inserted) and on back of rear a lower roll center block (option part) with 5 out
Old 05-10-2013 | 07:39 AM
  #3728
Stock for the 2.0 is Blue front and red rear. V2 springs, they are different than the V1.
DsWright is offline
Old 05-10-2013 | 07:40 AM
  #3729
i did pick up the LRC rear bracket also, haven't installed it yet though. but might this weekend. Will be running outdoor for the first time in 10 years, so this will be fun
DsWright is offline
Old 05-11-2013 | 06:43 AM
  #3730
Seems like stock springs are way to soft on rear
Old 05-12-2013 | 06:58 AM
  #3731
DPowers's Avatar
After a more than a year off i will be buying this for my first ebuggy looks like the best deal out for an rtr anyone know anything about the electronics that are on it.
DPowers is offline
Old 05-12-2013 | 08:42 AM
  #3732
I don't know anything about it but looks the same as 1.0 so 2.0 upgrades, shocks, ect should fit it
Old 05-12-2013 | 12:52 PM
  #3733
Is it just me, or does 2.0 not have dust boots on the axles?
ignis is offline
Old 05-12-2013 | 02:36 PM
  #3734
chicky03's Avatar
Not in the front. None of the models have them in the front, only rear.
chicky03 is offline
Old 05-12-2013 | 03:30 PM
  #3735
Well, that sucks And makes no sense, I can't think of a single reason why a manufacturer would want to expose CV joints to elements...
ignis is offline
