Serpent 811E Buggy Thread >
Like Tree5Likes
Old 03-14-2012 | 07:47 AM
  #1741
Maxxingout's Avatar
What are the set screws for that go into the hubs ?
The holes are ment to be used for a clean out (remove the set screw).
Maxxingout is offline
Old 03-14-2012 | 08:57 AM
  #1742
bronc4now's Avatar
Originally Posted by tony montana
They should have been in the bag that had the hubs. There not the same size as the ones that go in the sway bar there longer
What not where ...
So how does that work? clean out ? like with a spray in the hole to flush out bearings ?
bronc4now is offline
Old 03-14-2012 | 09:03 AM
  #1743
blade329's Avatar
R/C Tech Elite Member
Yes. Mugen has the same deal. You just spray WD-40 in the hole until the fluid comes out looking clear.
blade329 is offline
Old 03-14-2012 | 09:04 AM
  #1744
Maxxingout's Avatar
Yes but I personally won't do that. With sealed bearing you have no need for cleaning & blowing out. I'd rather, when the time came, take the bearings out and clean everything that way.
Old 03-14-2012 | 10:00 AM
  #1745
bronc4now's Avatar
Ok thanks that's a new one to me ..just wanted to make sure I wasn't missing something..
Old 03-14-2012 | 10:25 AM
  #1746
Maxthepersonz's Avatar
So are you guys cleaning your bearings like this regularly? Do they last as long?
Maxthepersonz is offline
Old 03-14-2012 | 10:44 AM
  #1747
GMS_Racing's Avatar
Ive used the cleaing holes once, all they do is blow all the plastic dust from inside the hub into your bearing and destory them. Your better of justpulling them and cleaning them.
GMS_Racing is offline
Old 03-14-2012 | 11:12 AM
  #1748
RCmayor's Avatar
Any companies have plans for carbon fibre battery hold downs for the 811Be?
RCmayor is offline
Old 03-14-2012 | 02:01 PM
  #1749
bronc4now's Avatar
I asked the same ? Before the stock ones are just as light . It would be mostly for looks ..
Old 03-14-2012 | 02:40 PM
  #1750
RCmayor's Avatar
Ya, mainly for looks. Might have to get some graphite plate and make a mess cutting some out. :-)
RCmayor is offline
Old 03-14-2012 | 07:36 PM
  #1751
DragKel's Avatar
Default Steering rack
Planning to get the option steering rack for more ankerman, option 1 is more and 2 medium but how do i choose the correct steering rack? Any guide line?
DragKel is offline
Old 03-15-2012 | 12:53 AM
  #1752
Originally Posted by mrnizzles
thanks for the info on Amain, and would like to post a link to their part from M2C that covers the front shock towers. but I need more posts, doh!
I think its for the nitro buggy, just wondering if they would fit the e-buggy version as well..
M2C Racing Serpent S811 Front Shock Tower Bra
[M2C3701]
I have this M2C shock tower bra on mine and it does a nice job of protecting the CF towers.
Vortexted is offline
Old 03-15-2012 | 01:18 AM
  #1753
Originally Posted by bigjayjay1
Check out the high velocity thread he sells 2s 6000 60c lips awesome performance meets and even exceeds thunder packs. His name his neuracer aka Jon. Right height is adjust as you would place on the track.
http://www.rctech.net/forum/electric...rds-lipos.html
I checked those out before I bought the nano techs but Jon was out of about everything and his prices were pretty much the same as Racers Edge and other high dollar brands. The Turnigy Nano Techs have been outstanding in my 10th scale cars and in my 811E, and they are 40% of the price. You just have to wait 7-10 days for them to be delivered from China.
I got about 4 runs in tonight and the 811E ran GREAT! I used Porkchops setup less the sway bar and 1.3 pistons(will try that tomorrow), and I was impressed. My race buddy who normally whoops my ass and laps me was barely staying out in front of me with his Mugen, with the same RX8/1900 combo. He did go over to the RCSHOX dual stage pistons and his car was eating up the ruts and rhythm section a little better so I'm going to buy some and give them a try. Although I don't have a 1.3mm piston drill bit, using stock tapered 8 hole piston.
Anyone else here running dual stage pistons?
Twice tonight my screw came out of the link attached to the front shock tower though I'll Put some red lock tight on it next time since the blue was not holding.
I ran it on a large 10th scale track as well that my 10th buggies struggle with and the 811E was amazing, that track almost seemed to easy now.
On the 8th track In the beginning I was forgetting to let off the throttle on the big monster triple and had some BIG end over end crashes, nothing broke......tough car!
And all the compliments I'm getting from others, everyone is impressed with the build and looks of the Serpent.
More to come....I'm addicted
Old 03-15-2012 | 08:23 AM
  #1754
bigjayjay1's Avatar
Jon battery arent cheaper then the HK stuff but you pay for quality and service pretty simple. If your referring to the turnbuckles coming lose run a longer screw and a nut.
bigjayjay1 is offline
Old 03-16-2012 | 01:11 AM
  #1755
Tonight a schock standoff broke Considering the beating I put her through tonight I'm surprised that is all that broke. I will certainly keep a spare of those around for now on.
I take that back, my MC2 shock tower bra partially broke as well at the same time the standoff broke. But it's still functional.
