Serpent 811E Buggy Thread >
Like Tree5Likes
Old 12-08-2011 | 09:55 PM
  #991
spunkysandoval's Avatar
Does anyone know if the kit rear sway bar is 2.3mm or 2.5mm?
I just ordered a 2.5 to try and get some more steering but I'm not sure if that is what I have already. The manual says it comes with a 2.3 but serpent manuals are always behind the times.
spunkysandoval is offline
Old 12-08-2011 | 10:06 PM
  #992
big greg's Avatar
did I see someone post about missing nuts? I am.missing like 20 of them, and a bunch of countersunk washers, and when I was putting my diff.together one of the cross pins had the notch way off to the side, can't believe this for a 550$ kit
big greg is offline
Old 12-08-2011 | 10:08 PM
  #993
teeforb's Avatar
You can measure it with Calipers. It should be exact. If u don't have one, harbor freight for around $20.
teeforb is offline
Old 12-08-2011 | 10:10 PM
  #994
teeforb's Avatar
The plastic nuts and counter sinks are in a seperate bag. Not sure if you are missing that bag.
teeforb is offline
Old 12-08-2011 | 10:13 PM
  #995
Bonadona's Avatar
The kit rear bar is a 2.5
Bonadona is offline
Old 12-08-2011 | 11:14 PM
  #996
Awesome! I'll change my order then and get the bladders instead of the sway bar.
Just threw the 2.0mm sc10 4x4 rear sway bar on the front and its a direct replacment! No fitment issues whatsoever and no binding. This should help my steering quite a bit along with the shocks in 1 hole on the front shock tower.
I did some trimming to my body at the track and I observed temperature drops of nearly 40* on my motor. Here is how I trimmed it.
Old 12-08-2011 | 11:46 PM
  #997
one of my cross pins had the notch way off also. i just used a dremel to make a new notch. was annoying tho
psionic is offline
Old 12-09-2011 | 06:25 AM
  #998
Frank L's Avatar
That are plastic and on a parts tree in a bag all by themselves.
Frank L is offline
Old 12-09-2011 | 06:35 AM
  #999
big greg's Avatar
the nuts holding the diff together through the shock tower are plastic? why would they do that, ill just go pick up some real ones after work
big greg is offline
Old 12-09-2011 | 09:19 AM
  #1000
Frank L's Avatar
Frank L is offline
Old 12-10-2011 | 12:15 AM
  #1001
Originally Posted by Frank L
Anyone with a stock serpent 8x19 pinion that can measure the width?
I'm building mine at the mo, the width of the shaft is 7.99mm. So a small clearance to fit an 8mm ID bearing. I measured the bearing as well at 7.99mm but this was only with a verneir calliper which you cannot considered to be accurate enough for this type of measurement. The bearing ID must be slightly bigger as it fits nicely over the pinion.
Badger5 is offline
Old 12-10-2011 | 05:43 AM
  #1002
Frank L's Avatar
Thanks for the response.
Frank L is offline
Old 12-10-2011 | 12:26 PM
  #1003
Forgot to a add the width of the bearing as asked a few posts back, I measured it at 5.97mm for the inner and outer race.
Badger5 is offline
Old 12-10-2011 | 01:46 PM
  #1004
cheers badger.
Captainlip is offline
Old 12-10-2011 | 07:02 PM
  #1005
ran mine for the first time tonite. Awesome buggy that worked very well with the box setup. Didnt change a thing on a slightly damp track with AKA Ibeams. I was immediately in the top three in the 1/8 nitro class. Not enuf 1/8e buggies so we all race together. I even won the first heat and against some very good drivers. Very confidence inspring buggy. I am happy, very happy.
todb is online now
