Like Tree5Likes
SC10 4x4 Thread
Old 12-13-2011 | 11:33 AM
  #12451
Grouchman's Avatar
Originally Posted by Adonis_mp
Is there a need to upgade to SC10 4X4 Aluminum Screw Set?
No, it's meant more for looks!!!!
Grouchman is offline
Old 12-13-2011 | 12:08 PM
  #12452
They do weigh less, but I would rather spend 40 bucks on something else. Like Mantis' new center diff.
Kbmoss is offline
Old 12-13-2011 | 12:32 PM
  #12453
Grouchman's Avatar
The bolts are lighter, but you don't want to take weight off the truck, you need to add more weight. I don't know about everyone else, the Losi trucks can push an SC10 4x4 out out the way very easily. Spend the money on Mantis new center diff, Coyote's chassis brace, Exotek chassis, or something that will make the truck run better.
Old 12-13-2011 | 12:41 PM
  #12454
+1. Well said. And nobody sees your blinging FT bolts except when your truck is sitting in the pits on your stand with the lid off. I guess for some if it looks good it must be fast.
jamr1130 is offline
Old 12-13-2011 | 12:56 PM
  #12455
Originally Posted by T-BirdJunkie
This truck is sweet Im thinking of selling my sc10 4x4 and get this truck to race I bet I would TQ every race and win all the A-mains lol J/k
special_k is offline
Old 12-13-2011 | 01:04 PM
  #12456
Adonis_mp's Avatar
I keep reading refrencese about getting a new center diff but would the Associated Factory Team Version 2 Slipper Hubs be a good and cheaper option, or we could be talking aboout a diffrent thing.
Adonis_mp is offline
Old 12-13-2011 | 01:10 PM
  #12457
symmetricon's Avatar
You can pre order the center ball diff at
rcshox.com
symmetricon is offline
Old 12-13-2011 | 01:18 PM
  #12458
Slotmachine's Avatar
Originally Posted by JayL
4-5mm front inner camber shim
2mm rear inner camber shim
thicker front diff oil
barcodes, as you run, but with JC Hazard rims (+3mm wider)
really helped me
also getting off throttle early then taking sweeper on-power
You do know that these adjustments are ride height sensitive? Camber links change angle with ride height...................
Slotmachine is offline
Old 12-13-2011 | 01:27 PM
  #12459
Resqnu's Avatar
Default Motors?
Do you guys prefer the 550s or 540 4 poles? I am currently running the Novak 550 5.5 HV and seems to have plenty on power. Just wondering if I am missing out on something as a lot of guys are running the Tekin pro4s and castle 1410 3800.
Resqnu is offline
Old 12-13-2011 | 01:32 PM
  #12460
Wild Cherry's Avatar
Tech Legend
The 4p motors have way more power , not necessarily the
best motor though .
Your motor is just enough , if you need more ?
Dail in some boost ,
been using quite a bit of the boost with the same motor ...
Wild Cherry is offline
  #12461
The new viper 550 4 poles will be out in two weeks, i dont think anything out right now is gonna be able to touch them!!!! And they are only 150 dollers with a badass speedcontrol
rickybobbyxxx is offline
Old 12-13-2011 | 01:41 PM
  #12462
Resqnu's Avatar
Thanks, so I take it the 550 motors are all around better for our trucks? I am running my Novak 5.5 with the mmp. Should I dial in boost with the mmp if needed? Are many using this esc?
Resqnu is offline
Old 12-13-2011 | 02:47 PM
  #12463
anyone else have there diff outdrives wear out and get wobbly on them mine are toast and the other problem is the cva pins I've broke two of them and I know others that have also seems like the hub bearing moves and allows the pin to come out alittle then it sheers it.
kevink123 is offline
Old 12-13-2011 | 03:03 PM
  #12464
Chad Smith's Avatar
Yes EVERYONE has had wobbly outdrives. What most people did was add 1-2 shims in the diff to get rid of some of the wobble. Make sure though when you add the shims, the outdrives arent to tight or binding.
Chad Smith is offline
Old 12-13-2011 | 03:46 PM
  #12465
vito's Avatar
got some money saved up where to get a kit at on line
vito is offline
