SC10 4x4 Thread
#9661
#9662
#9663
#9665
#9667
You guys gotta try the STRC shock collars...I'm not sponsored by them but they are SO much better than the stock collars that turn so loosely. Try checking the stock collars after a run. I've had mine loosen up durings runs, thats not gonna happen now for sure!
#9668
From: Norwood, OH...and CCRCR and The OhioRCFactory
Do some experimenting
#9671
You might want to try a different spring on each shock...the differing tension on each corner will offset each shocks fluidic motion therefore re-enacting the xx-4 worlds performance on the track in Finland.
I'm just kidding...wait a minute...your running a sc10 4x4...not a xx-4...but they're kinda the same thing so it might work
...again don't listen to me!
#9672
#9674
I'm not quite sure what my ride height is...(i don't have a measurement device
) But, I can tell you my shock collars in the front are all the way up, and the backs are only down about 3-4 mm. I did have to limit all four shocks by 4 mm for up travel since I removed the boots, but other than that, it's been awesome.
#9675
I'm running 35 front, 30 rear also. I noticed when i went from bladders to emulsion, it gave the truck a lower ride height then the bladder shocks had. No other changes were made, and the ride height was about 2 mm lower. Maybe it's nothing more than raising your ride height up a little bit??? That's all I did, and I have not gone back to bladders since. I think it gave the truck a more softer, more responsive feel, which is what I was after.
) But, I can tell you my shock collars in the front are all the way up, and the backs are only down about 3-4 mm. I did have to limit all four shocks by 4 mm for up travel since I removed the boots, but other than that, it's been awesome.I really appreciate the input. I set up with a suggestion from T-Eagle. I'll be out there testing all day Sunday and return with my results. It's gonna rain Saturday! So the Track will be perrrrrrrrrrrrrrrrrrrrrrrfect for Sunday.
(no, we have no electricity or water available for the track. We are bum'in it.)
5Likes
